NAS D90 frame isn't as heavy as I thought it would be - Defender Source
Old February 12th, 2014, 12:15 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Talking NAS D90 frame isn't as heavy as I thought it would be
I thought I wouldn't be able to move it around myself but I was able to slide it off the uhaul safely until I had a friend come over and helped me move it into position. I'm guessing It weighs around 500lbs. Finally got it near the D90, now its time to start installing them tasty Chinese terrafirma front and rear trailing arms and shock towers.
ID:	89566   Click image for larger version
ID:	89568   Click image for larger version
ID:	89570   Click image for larger version
Robert Deniro
Old February 12th, 2014, 12:23 PM
Neil McCauley
Neil McCauley
I'm going to take apart the front end only to expose the engine better, than buy a harbor freight boom crane lift thingy..whatever they call it and use 55 gallon drums on the back end. I'm going to have several friends help me lift the rear tub onto a 2x2 bar to support the rear. Than roll the frame out and begin the parts swap. I have a brand new tasty 4.6 to drop in as well.
Robert Deniro
Old February 12th, 2014, 12:49 PM
themaxx's Avatar
themaxx
Ade
94 ST
I thought you curled more that.
Old February 12th, 2014, 12:54 PM
Neil McCauley
Neil McCauley
The most I ever curled is 235 on a straight bar. (with swinging of course) I use to bench 530 but now I'm old so lately the most I can do is about 455 now. I'm really excited about starting my build finally. I've been busy at work but now that the gf moved back to NY I'm going to try to squeeze in at least a few hours of wrench time a week.
Robert Deniro
Old February 12th, 2014, 01:33 PM
I'm assuming this friend was Barry?
Old February 12th, 2014, 01:50 PM
Neil McCauley
Neil McCauley
Gayness aside, does anyone have any advice as to how I should deal with the serial plate? Should I plasma cut the plate off than weld it onto my new frame or just leave it as is?
Robert Deniro
bjf's Avatar
bjf
barry f
94 ST #395
Britpart?
No way anything is lining up on that thing. Steal a box of chop sticks from your parent's restaurant. You are going to need something for shims.
------ Follow up post added February 12th, 2014 10:53 AM ------
I would buy a die set and re-stamp.
Horsey can you fly out so Neil can use your legs as jack stands. They are perfect. Super strong and only two feet off the ground.
Old February 12th, 2014, 01:54 PM
Neil McCauley
Neil McCauley
Also I was surprised the transmission cross member wasn't included. Luckily mine is still ok, just need to get it galvanized.
------ Follow up post added February 12th, 2014 10:56 AM ------
[QUOTE=bjf;507148]Britpart?
Do you know anyone that had issues with the britpart frame? I thought worse case scenario I might have to enlarge a hole or 2 with drill bits.
Robert Deniro
Old February 12th, 2014, 01:56 PM
Originally Posted by bjf View Post
Britpart?
They are built by Richards or Marsland and just resold by BP.
Old February 12th, 2014, 01:59 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Britpart?
You're in prime form.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
bjf's Avatar
bjf
barry f
94 ST #395
Makes sense.
Neil,
Let me know if you find a local galvanizer. I need to galvanize everything on my truck. I have some really harsh conditions in my garage and I need my truck to be protected.
Old February 12th, 2014, 02:08 PM
Neil McCauley
Neil McCauley
Barry sarcasm aside, there actually is some rust on my crossmember, on the flat ends that mount to the chassis. Nothing real serious but I guess if I don't galvy I could just paint it with silver rattle can.
Robert Deniro
Old February 12th, 2014, 02:27 PM
ezzzzzzz
Mark Garrenton
Keep the old front horn with the VIN. You'll probably need it if you're ever questioned about the missing or self-inflicted VIN over the galvanizing of your new chassis.
Old February 12th, 2014, 02:34 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
You will want the new frame inspected by the CHP. They will want to see the old vin number (if possible) a receipt and proof of origin for the new frame. Then they will either stamp the vin on, or provide you with the paperwork to show that the frame swap was done legally (that part I wasn't clear on).
Old February 12th, 2014, 02:36 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
http://www.roversnorth.com/ProductDe...AS-GALV&key=it
Old February 12th, 2014, 02:49 PM
Neil McCauley
Neil McCauley
Thanks, great idea actually. If anyone wants the good parts they can come over when its ready to strip.
------ Follow up post added February 12th, 2014 11:51 AM ------
Mine is still good, just surface rust on the parts that the factory didn't paint. I'm just going to galvy or paint, depending on how far and how much. Thanks for the link though.
Robert Deniro
Old February 12th, 2014, 03:09 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Instead of silver paint why not just spray it with cold galvanizing paint? Buy it at one of the big box hardware stores in the spray can aisles.
Old February 12th, 2014, 03:17 PM
Is the NAS crossmember different that normal 90s? New galv ones are less than $100.
Old February 12th, 2014, 03:23 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
yes, V8 cats need to run under the crossmember. Tdi crossmember are squared at the bottom.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 12th, 2014, 03:27 PM
http://www.roversnorth.com/ProductDe...e=0&eq=&key=it
d90, ht, nas, 90
a load of D90 parts for sale ron For Sale - Parts 41 May 1st, 2005 03:32 PM
considering d90 toolman Misc. Chit-Chat 7 March 28th, 2005 02:36 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
