NAS 110 Advice - Defender Source
Old March 7th, 2009, 02:15 PM
pcscharfe
pcdefender
D90/NAS 110
Thumbs up NAS 110 Advice
Anyone want to weigh in on these pics? I am shopping a 110 right now and here are a few pics. I am hoping to get straight answers from the owner, but if anything strikes you, please let me know.
1.) Has anyone else here installed cruise control in there 110? This appears to be the case for this one (additional switch on steering column), so i wanted to know if others had done so, and if there were any potential pitfalls.
2.) Floor paint... It is tought to tell form the pics, but i get the sense that the floors have been repainted to some extent (not reassuring). However, if this looks normal please let me know. That white overspray on the rollcage bracket seems a bit suspect. It is a Land Rover, however, so i leave open the possiblilty that LR just did a shit job when they painted the area. Anyone have "factory overspray" in their 110, or should i continue to assume the worst.
Thanks.
Paul
ID:	18121   Click image for larger version
ID:	18123   Click image for larger version
ID:	18125   Click image for larger version
ID:	18127   Click image for larger version
Old March 7th, 2009, 02:40 PM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
Paul,
Just based on the pictures I am seeing, it looks like a really clean truck.
The floors have been painted, but I don't see that as a big deal. The area right along the outer floor at the bottom of where the door closed is problematic for rusting on these. The new 110's don't have that extra piece of metal on them and the bottom seal is actually on the door bottom itself.
I believe that ECR does this better set up on their restorations as well.
The other area to get some surface rust is the upper capping on the rear tub. Looks like yours was repaired and spot painted to prevent further corrosion.
These do not look like deal breakers to me.
Your main concern is rust in the bulkhead area and the frame.
As far as the cruise-control, ... it was probably something moved from a scraped classic or the like. Never seen it on one of these.
Dendy
Old March 7th, 2009, 03:22 PM
That cruise control is a common aftermarket model. It has the distinctive stalk. Overspray and a repainted floor is better than one you can poke your fingers through. If its a SoCal truck, it might be OK. I've got records on the first 260 or so, so if the number is less than that, shoot me a PM and I'll tell you where its been all its life.
Old March 7th, 2009, 08:25 PM
Ron want cruise control if you remove it.
Old March 7th, 2009, 08:39 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Keep looking.
What tree?
Old March 7th, 2009, 08:41 PM
I wish my Defender had cruise control. That truck needs some new valve cover gaskets something terrible. I think 110's are way over price and way overrated.
Old March 7th, 2009, 09:56 PM
ORover's Avatar
ORover
Fred
NAS 110s #24 and #466
My original paint 110 has no overspray. Looks like you have overspray by the roll cage too which is not original. That paint on the floor looks to be added to cover rust. Better check the battery compartment too.
Thanks.
Paul
Old March 8th, 2009, 12:53 PM
pcscharfe
pcdefender
D90/NAS 110
I really appreciate all the input from you guys. Corrision is the obvious #1 concern. With the touch-up/cover-up paint that is apparent, it really needs to be inspected in person. Indeed, the valve cover is a leaking mess, but the mechanical issues dont put me off at the moment...
I'll report back once i have had the oportunity to see it in person.
Ron, if it ends up in my garage, you're first in line for the cruise control.
Thanks guys!
Old March 9th, 2009, 10:08 AM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
just remember you may need a new hood and new tires =)
keith humphreys
keith . humphreys @ me . com
617 . 308 . 4100
110, nas, nas 110
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
NAS 110 A/C questions rcork Defender Technical Discussions 13 July 19th, 2005 01:16 PM
110 tried almost everything and it is still overheating.need some advice draaronr Defender Technical Discussions 21 November 17th, 2004 07:25 AM
OD of NAS 110 cage needed dnewman9 Defender Technical Discussions 1 July 4th, 2004 01:24 AM
