my d90 update - Defender Source
Old February 11th, 2007, 06:29 PM
huck1974's Avatar
huck1974
shane cates
94 d90
my d90 update
I have spent some time sorting things neglected from the previous owner before tackling any serious upgrades. It sure kicks ass having a lift. Overall, everything is pretty good. Mostly light surface rust and mud underneath with the exception of the fuel tank carrier. I will make a new one out of a much heavier guage steel and swiss cheese it a little for water drainage. I should be able to mass produce that pretty cheap if I can help anyone out with a viable alternative to the 150$ galvanized part. Keep in mind, I am not a vendor, more of a buddy deal thing.
I will put it on the lift and give it the heated pressure washer treatment as soon as the weather turns. Then I will give it some rust protection and we will be good for another five years or so.
I noticed a small drip from the front diff pinion seal and ordered on from rovers north although I am learning that some of the parts can be found for a lot less with a little research. I found that the parking/trans brake was not holding well and saw that the cable adjustment was ran pretty far out already. This led me to pull the drum for an inspection and found that the transfer output seal is bad. I adjusted the drum for a temp fix while waiting for the new seal.
The oil pan plug is dripping but I will wait to fix it when it needs a change.
One of the little green condom covered light bulbs was bad on the tach and is on order.
I slapped in a kenwood and some waterfroof 6.5" speakers as well as a xm setup. Got used to no commercials.
decided to retain and just modify the existing front bumper setup by welding on a plate between the frame wells for stability and extending it for a 9000lb setup and some recovery areas, without really altering factory looks. Should be done next week and sent to the powdercoaters.
My neighbor, the custom chopper fabricator, is going to design my jerry can racks as well the highlift mounting points for the back, making use of the existing tire carrier.
I am very interested in the safari gard lift setup or any others you guys/gals have experience with as well as their road manners.
I will keep you updated on the diesel swap.
Thanks for listening to my ramblings and your suggestions would be appreciated.
Old February 11th, 2007, 11:54 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Man, you are making me feel like a bump on a log! Seriously, you have gotten more done than I have in the last 6 months I have the SG Stage 3 lift w/ the 3-Link and it works just fine. I think the only thing that really has set SG apart in the past from other companies is the 3-Link. If you go with the search route in this site you will find a lot of information on other vendors that produce great suspension kits.
Old February 12th, 2007, 09:24 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Like this carrier
http://www.rovertracks.com/images/cu...ierfinalTH.jpg
Not sure if SG is still selling their own springs or OME with spacers. If you will be getting their springs (super long with 5 dead coils) then go for it, but if they are selling the kit with OME and spacers then just build your own suspension setup. Just get the 3-link from them, it's worth it.
World traveler
Old February 12th, 2007, 12:19 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Originally Posted by TwisteD90
Like this carrier
yes, nice looking rack. thanks for the info
Old February 12th, 2007, 02:17 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
I ordered my SG suspension about a year ago and they were using the OME coils and spacers to get the 3" of lift. I went w/ Rovertym springs instead. I agree, get a 3-Link w/ the HD cross-bar.
Old February 12th, 2007, 08:25 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Very cool project you got there. Keep us all in the loop. Something to consider, that engine with weight and torque will overwhelm both the front springs and the drivetrain. Be sure to keep that in mind as you get going.
Dave
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 12th, 2007, 08:35 PM
huck1974's Avatar
huck1974
shane cates
94 d90
thanks buck. look forward to your input more.
90, d90
D90 EPROM update BajaF250 Defender Technical Discussions 2 February 18th, 2008 11:50 PM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
