Mounting lights to plastic bumper - Defender Source
Old March 25th, 2015, 10:48 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
It may recall I picked up that Eurovan Camper last fall, it's in much need of some aux lighting. Probably just a set of hella 500's or 1000's.
I know I want to mount them to the bumper. There is no "A" bar etc to mount to, so all I have is the plastic bumper.
Is anyone familiar with any mounting solutions or tricks/tips for something like this?
Many thanks
Old March 25th, 2015, 11:04 PM
It there any steel behind the license plate mounting area? If so a small bracket could be fabbed up to use the license plate mounting screws and you could mount your lights to that.
Old March 25th, 2015, 11:15 PM
josh-man's Avatar
josh-man
joshua
Crafty idea Dave. I have no ventured to take the bumper cover off or really pike around because it's been so FRACKING cold! But my list is long now that spring is in sight.
------ Follow up post added March 25th, 2015 11:16 PM ------
Jeff that's a rough van! No P38 wheels but I did just put some Mercedes wheels on it which look beautiful!
Old March 26th, 2015, 12:52 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Do you want whatever you decide to be reversible? I have a couple of ideas, but modifications would be necessary.
And Mondials are awesome! ;-) I have half a mind to find a set in a yard, paint them black, and call them my poor man's Kahns! 18" obviously will never be 20", but defenders were never supposed to roll on dubs! ;-) And my apologies for the sidetrack, but I just can't think about Kahn Defenders without first getting riled like Kirk and thinking of.........
The other half of my mind says "let it be!" They do look flash on my '98 P38 though!
ID:	116908   Click image for larger version
Old March 26th, 2015, 01:01 AM
D90Overkill
David Frank
1995 ST #2615
Another idea is to go with an altogether different hella and replace what you have or flush mount into the area of field plastic above the bumper.
http://hellahd.com/index.php/default...-beam-halogen/
http://www.awdirect.com/hella-double...t-work-lights/
Old March 26th, 2015, 07:45 AM
Hella makes replacement grilles with lights built in for many VW models. Might be a dead end but worth a look.
Plan B, Hella 1000 or LED lights direct on bumper
Old March 26th, 2015, 08:47 AM
josh-man's Avatar
josh-man
joshua
Originally Posted by Rocky View Post
Hella makes replacement grilles with lights built in for many VW models. Might be a dead end but worth a look. Plan B, Hella 1000 or LED lights direct on bumper
Rocky I'm coming up dry on hella- but thinking this is the way to do.
Defender A Bar for mounting lights spammer Wanted 1 December 30th, 2013 12:40 PM
Mounting lights Landyman1 Defender Technical Discussions 23 December 5th, 2013 12:29 AM
Is there good metal or plastic fan replacement for the plastic D90 radiator? Neil McCauley Defender Technical Discussions 8 December 12th, 2011 08:30 PM
Mounting Lights to the Bar michael15 Defender Technical Discussions 3 February 9th, 2006 08:49 PM
ARB Bumper Mounting Hardware dnewman9 Defender Technical Discussions 1 February 1st, 2004 04:04 PM
