more oil cooler lines - Defender Source
Old December 1st, 2004, 10:06 PM
When I was last driving my Rover I was thinking fuck what if one of those oil cooler lines burst my 90 would burn to the ground. Our trucks are getting old Have any of yall considered this? I wonder what would be the best fire extinguisher to get would be A new project for when I am home next I suppose.......
Old December 1st, 2004, 10:52 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
They are more likely to blow at high RPM, which induces higher pressure. So if in doubt, dog it until you can get replaced or upgraded lines. Get two extinguishers -- I used BOTH to put out my fire. And have them HANDY. Doesn't matter but dry chem leaves an ugly rotting mess. I'm carrying Halotron at the moment.
Doug W.
Old December 2nd, 2004, 07:28 AM
I carry one I bought at Home Depot.
http://www.defendersource.com/forum/...e+extinguisher
Old December 2nd, 2004, 11:01 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
replace them.
Old December 2nd, 2004, 11:16 AM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Does anyone have a good source for the oil cooler lines in the Denver area?
for a '97
--Benjamin Franklin
Old December 2nd, 2004, 11:44 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
At around $100 per line, I'd definitely NOT suggest the dealership. Somebody recently posted their results from bringing the stock lines down to a welding shop to replace the flexbile portion. Was a really nice install, cost less, and added quick disconnect fittings to make it even easier and cheaper to replace the next time.
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 2nd, 2004, 03:01 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
All this talk of lines bursting and trucks catching fire had me paranoid. I couldn't find a shop locally to replace the hose portion so I just bought some new lines from AB for around $160 (for both).
Old December 2nd, 2004, 03:03 PM
Doug's Avatar
Doug
Doug Walker
My guess is that if you are using stock replacment lines, if you replace every 5 years you'd be okay. I can't think of an oil fire that occurred within the first 5 years life of these rigs. Someone correct me if I'm wrong....
Doug W.
Old December 2nd, 2004, 03:18 PM
If anyone wants their lines done, let me know. You can just send them to me and I'll have my source do them.
Old December 2nd, 2004, 03:36 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
Now I'm paranoid, too. I'll have to check the service records and find out if they've ever been replaced.
Abel
Old December 2nd, 2004, 04:15 PM
PT94D90's Avatar
PT94D90
Phil
Doug - I was thinking the same thing. 5 yrs peace-of-mind is worth $160.
Old December 2nd, 2004, 05:06 PM
jabber
m j
110
What exactly is done to them? Do you have a pic or could you get a pic? I'd really be interested.
Jabber.
Old December 2nd, 2004, 06:35 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
So... this oil thing is real? The guys in Torrence spoke of this, especially in the older Defenders - I have a 1994. Price to fix it was about $250.00
I didn't do it because they never bothered to call me back and set the appointment (both for this and a few other things).
Should ths oil thing be fixed proactively??
This thread will answer all your questions - just let me know. I'd like to get a few together if several people want it, I'd rather not take lots of trips downtown.
http://www.defendersource.com/forum/...ead.php?t=3585
Fix it proactively! My d-90 almost got toasted!
Old December 2nd, 2004, 08:06 PM
Doug's Avatar
Doug
Doug Walker
The oil pressure lines get old and brittle, and they EXPLODE and spray oil on the manifold and cats = fire. This, and maintaining your brakes, are the most important service items you can perform. More important than changing the oil. Am I clear?
DW
Old December 2nd, 2004, 08:36 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
I worked my way through all of the service records looking for any indication that the oil cooler lines had ever been replaced or purchased. The lines on my truck are apparently 9 years old. It's parked and out of service until I can replace them. Damn the luck, I just changed my oil, too! This forum is great, without it I'd have no idea that my truck could burn to the ground so easily. Thanks for all the great information.
Abel
Old December 2nd, 2004, 09:06 PM
Hans's Avatar
Hans
Hans Haase
Yeah, they are on the slate to replace with the next oil change on mine too. What a pile of stuff to do! Does anybody have the thread pitch available for them, so I can try and source some Earl's fittings? I wanted to go with some braided stainless hoses for them.
Worst case, I'll just take them out and bring them to my parts guy with a call of "Replace This!"
-Hans
My oil line fix
Old December 2nd, 2004, 11:16 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
Hans,
How old are your lines?
Abel
Old December 2nd, 2004, 11:35 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Mike, the guy that rebuilt my alternator in Boulder also does these lines (and is recommended by Charlie). He is "Simcor" I believe--pm me if you need his number
Old December 2nd, 2004, 11:45 PM
Hans's Avatar
Hans
Hans Haase
Well, I can only make a guess on the age of the lines. Thankfully the previous owner was manical with reciepts, so I was able to research it a bit.
Best I can figure, they were installed in Solihill in late 1993 :-)
I am planning on replacing them this weekend while I do the head gaskets, cam, timing chain and try to track down the radiator leak.
-Hans
My oil line fix
oil cooler lines CHRIS C Defender Technical Discussions 39 December 21st, 2004 11:30 PM
Oil cooler lines revisited rover4x4 Defender Technical Discussions 5 July 9th, 2004 08:40 AM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
