Mobil 1 vs. Rotella - Defender Source
Old April 20th, 2008, 03:24 PM
Mobil 1 vs. Rotella
Almost hate to ask but what do you folks think has the better detergent? Ive been running the Mobil for like 30k so I imagine things are pretty clean. Just bored. I am going to do the passenger side valve cover again and will be anxious to see how things look after the Mobil diet.
Old April 21st, 2008, 10:28 AM
Are you talking for a diesel?? If gas, then why talk about Rotella as that is a diesel engine oil? If there is any build-up whatsoever within any engine, you are so far from using a good oil, it is not worth having a conversation....
Mobil 1 should not be used in a diesel.
Mobil makes two oils suitable for a diesel. Mobil Delvac 1 and Mobil Turbo Diesel Truck 5W-40. AFAWK, they are both the same fluid in different bottles. It is probably the best diesel engine oil on the market.
However, the differences in performance between those oils and Shell Rotella T 5W-40 will be small.
Old April 21st, 2008, 05:51 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have used the Rotella since my Tdi was new. I like it. I would like to go to a synthetic but was told that It could start leaks in the engine... I have none as of now. I would go to the Mobil 1 though. Don't know how true the leaking is though.
Legend in My Own Mind.
Old April 21st, 2008, 06:17 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I've switched both my trucks over to Mobil 1 from dino oil and have noticed no increased leaking. Not sure what started that rumor.
Mobil 1 Commercial specops1526 Misc. Chit-Chat 0 April 27th, 2009 06:03 PM
Rotella T 15W-40 Grover Defender Technical Discussions 11 January 20th, 2009 09:19 PM
where to buy Rotella 5W40, in Mass artm Defender Technical Discussions 7 December 7th, 2008 06:33 PM
Mobil 1 in diffs? JBfoot Defender Technical Discussions 1 August 17th, 2008 02:35 PM
Mobil 1 in the diff's rover4x4 Defender Technical Discussions 2 November 14th, 2003 10:48 PM
