Missing part - Defender Source
Old July 23rd, 2012, 02:45 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Missing part
Hi. Can you guys tell me what is missing on the ABS pump. According to the pics I found on the old interweb, there is something that is supposed to be threaded in and it is green. It goes in right next to the name plates.
a link to a pic of the complete one
http://www.google.com/imgres?hl=en&c...w=1280&bih=615
then the actual one I have.
thanks
Old July 23rd, 2012, 02:50 PM
This is from a P38, right?
Old July 23rd, 2012, 02:51 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
The green thing is the pressure switch - it tells the pump when to turn off/on.
Semper Fi!
Old July 23rd, 2012, 02:59 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Wow. You guys are fast.
I believe it works with P38 and Range Rovers 95-02
Anyone need one? haha
Old July 23rd, 2012, 03:01 PM
Wolf Fabrication
Sterling Archer
'08 D3
I actually could use it if I can make it work with my '94 RRC.
Semper Fi!
Old July 23rd, 2012, 03:23 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
No idea how you'd do that. Everything I find says 95-02.
Old July 23rd, 2012, 03:27 PM
The pressure switch is what goes bad 90% of the time. Also, no way to retrofit to a RRC I have seen.
Old July 23rd, 2012, 06:00 PM
Wolf Fabrication
Sterling Archer
'08 D3
Actually, when researching my ABS issue, converting to the newer style P38 sounded like a common retrofit. It's the same system, except the accumulator is mounted on the pump itself. Everything bolts up and you need some sort of adapter line to convert an RRC line to the P38 pump.
Semper Fi!
part
Key won't open door - missing part JFD Defender Technical Discussions 2 July 3rd, 2011 07:38 PM
Fastback install - what is missing? paulb Defender Technical Discussions 10 March 17th, 2005 12:28 PM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
