Missed it by THAT MUCH! - Defender Source
Old September 2nd, 2015, 07:07 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Delete
Sorry, link has gone dead. It was a fully documented 1994 300tdi Camel used in 1996. Beautiful original condition with all the proper service wear and tear.
Old September 2nd, 2015, 07:28 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Was that the one the guy found out west in the desert?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 2nd, 2015, 07:30 AM
1of40's Avatar
1of40
1of40
no, this was a 110 300tdi the AZ one was a Disco iirc.
Old September 2nd, 2015, 07:32 AM
Ray_G's Avatar
Ray_G
Ray Gerber
The one out west was a Disco, and that whole thing turned into serious drama. A CT 110 would be badass.
Old September 2nd, 2015, 07:37 AM
Post pics! I'm sure One Ten bought it or at least saw it. Was it on Craigslist or something? $$?
Old September 2nd, 2015, 09:23 AM
Clay were these the pics? If so it'd said in the UK not AZ.
Land rover 110 original Camel Trophy 300tdi 1994 | United Kingdom | Gumtree
Title: Land rover 110 original Camel Trophy 300tdi 1994
Price: £13,750.00
Mileage: 79500
Seller Type: Private
Description:
For Sale an original 1994 300tdi Camel Trophy Land Rover.
Mileage 79500
This vehicle was one of only four Land Rovers to take part in the Pre scout for the 1996 Kalimantan event.
I have over the last four years spared no expense in maintaining the mechanical parts of this Land Rover.
The list of things I have done are:
Alternator fitted
New fuel tank
P/S Pump
Cam belt and pulley kit
Water pump
Pet gasket
All new glow plugs
New front wide angle prop shaft
All four wheel bearings
Turbo silicone hoses
New rear crossmember
New drivers and passenger side footwell
Halogen conversion kit for front head lights
Stainless steel exhaust
Mobile storage system window guards
New clutch master cylinder and slave cylinder
Head gasket
Exhaust heat shield
Rear dog guard
New rear pinion seals
New rear half shafts
Two new batteries
A split charge system
The front bumper has been shot blasted, galvanised and poly coated. The bull bars have been shot blasted and nylon coated. The front recovery points have been electro plated. These works were completed by Brownchurch.
The winch has just come back from a full service, it was working well off the Land Rover but however it seems to be slightly temperamental at the moment but should only be a lose connection.
The rear door has a fold down kitchen, with hand soap, fire blanket, and storage cupboard.
There is a Mantec rear door wheel carrier.
The Landy has done almost 79,000 miles.
It comes with the original pioneer tools, the Terra trip computer from the event and 4 sand ladders.
The upgrades carried out by Land Rover for the event where extensive, they include
A secondary fuel tank under the driverís seat with a fuel switch linked to the fuel gauge so you can change supplies whilst driving.
An internal/external roll cage by Safety Devices.
Full length roof rack and a 4 jerry can holder and ladder by Brownchurch.
It comes with an MOT with NO ADVISORIES!! expiring on the 24th February 2016.
Please note this is a 20 year old Land Rover that has been to Borneo!!
Do not expect a new car. Compared to other Camelís it is very straight.
However it does have marks, dents and scratches on the body work.
There is rust on the bottom of the doors and rust on the internal parts of the doors.
The wood sheets on the top of the roof rack are looking tired.
The Nato hook will be replaced with the original recovery point from the event.
It will also come with all 5 of the original Camel Trophy wheels.
But thatís about it. A great historic icon that will take you on an expedition or through a 4 foot water hole at the Billing Land Rover show.
Viewing is recommended.
Item ID: 1128790334
Name:	1994 Camel Trophy 110 1.JPG
ID:	128521   Click image for larger version
Name:	1994 Camel Trophy 110 2.JPG
Name:	1994 Camel Trophy 110 3.jpg
ID:	128523   Click image for larger version
Name:	1994 Camel Trophy 110 4.JPG
Name:	1994 Camel Trophy 110 5.JPG
ID:	128525   Click image for larger version
Name:	1994 Camel Trophy 110 6.JPG
Name:	1994 Camel Trophy 110 7.JPG
ID:	128527   Click image for larger version
Name:	1994 Camel Trophy 110 8.JPG
Old September 2nd, 2015, 09:50 AM
1of40's Avatar
1of40
1of40
Originally Posted by rijosho View Post
Clay were these the pics? If so it'd said in the UK not AZ. Land rover 110 original Camel Trophy 300tdi 1994 | United Kingdom | Gumtree Title: Land rover 110 original Camel Trophy 300tdi 1994 Location: Braintree, Essex Price: £13,750.00 Mileage: 79500 Seller Type: Private Description: For Sale an original 1994 300tdi Camel Trophy Land Rover. Mileage 79500 This vehicle was one of only four Land Rovers to take part in the Pre scout for the 1996 Kalimantan event. I have over the last four years spared no expense in maintaining the mechanical parts of this Land Rover. The list of things I have done are: Alternator fitted New fuel tank P/S Pump Cam belt and pulley kit Water pump Pet gasket All new glow plugs New front wide angle prop shaft All four wheel bearings Turbo silicone hoses New rear crossmember New drivers and passenger side footwell Halogen conversion kit for front head lights Stainless steel exhaust Mobile storage system window guards New clutch master cylinder and slave cylinder Head gasket Exhaust heat shield Rear dog guard New rear pinion seals New rear half shafts Two new batteries A split charge system The front bumper has been shot blasted, galvanised and poly coated. The bull bars have been shot blasted and nylon coated. The front recovery points have been electro plated. These works were completed by Brownchurch. The winch has just come back from a full service, it was working well off the Land Rover but however it seems to be slightly temperamental at the moment but should only be a lose connection. The rear door has a fold down kitchen, with hand soap, fire blanket, and storage cupboard. There is a Mantec rear door wheel carrier. The Landy has done almost 79,000 miles. It comes with the original pioneer tools, the Terra trip computer from the event and 4 sand ladders. The upgrades carried out by Land Rover for the event where extensive, they include A secondary fuel tank under the driver’s seat with a fuel switch linked to the fuel gauge so you can change supplies whilst driving. An internal/external roll cage by Safety Devices. Full length roof rack and a 4 jerry can holder and ladder by Brownchurch. It comes with an MOT with NO ADVISORIES!! expiring on the 24th February 2016. Please note this is a 20 year old Land Rover that has been to Borneo!! Do not expect a new car. Compared to other Camel’s it is very straight. However it does have marks, dents and scratches on the body work. There is rust on the bottom of the doors and rust on the internal parts of the doors. The wood sheets on the top of the roof rack are looking tired. The Nato hook will be replaced with the original recovery point from the event. It will also come with all 5 of the original Camel Trophy wheels. But that’s about it. A great historic icon that will take you on an expedition or through a 4 foot water hole at the Billing Land Rover show. Viewing is recommended. Item ID: 1128790334
that's it
Old September 2nd, 2015, 09:52 AM
rovertrader's Avatar
rovertrader
Dale
Very nice, and decent price too!!
Old September 2nd, 2015, 10:18 AM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
It's been for sale for over a month, cannot believe it took that long to sell. I was relentless in nagging the wife about this truck.
Patches are for Pirates and pants, not a bulkhead and chassis!
Old September 2nd, 2015, 10:21 AM
1of40's Avatar
1of40
1of40
I have the opposite problem. If I had proper space I'd be in trouble.
How much is too much??? Azarur Truck Build-up's & Restores 71 April 5th, 2015 01:55 AM
FML just missed a great deal on a tdi galvy chassis 83 110 evilfij Misc. Chit-Chat 4 July 8th, 2009 04:35 PM
Sagging Suspension: How Much is Too Much? aclarke Defender Technical Discussions 9 June 19th, 2007 04:41 PM
How much winch? howellm70 Defender Technical Discussions 45 January 31st, 2004 09:00 PM
how much should I pay for a starter Campbell Defender Technical Discussions 5 November 4th, 2003 02:38 PM
