mh370 mystery continues - Defender Source
Old August 29th, 2015, 03:10 PM
http://nymag.com/daily/intelligencer...ml?wpsrc=nymag
So the part that is supposed to be from MH 370 has discrepancies in maintenance details and spent several month several meters under water .. Added to that its missing the ID it should have.
Old August 29th, 2015, 03:45 PM
Additional interesting read:
How Crazy Am I to Think I Know Where MH370 Is? -- NYMag
Old August 29th, 2015, 03:52 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
The plane landed at a remote airfield in the desolate most eastern part of Iran. And the passengers are being held captive in caverns under the desert.
Sounds good anyway.
The truth about airplane parts. They are swapped quite often. If a part is damaged, it's not uncommon to cannibalize an airplane that maybe out of service for a lengthy routine maintenance, in order to get another airplane back in service.
Black Rhino Lives Matter
Old August 29th, 2015, 04:36 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Originally Posted by LuisC View Post
The plane landed at a remote airfield in the desolate most eastern part of Iran. And the passengers are being held captive in caverns under the desert. Sounds good anyway.
Cruise missiles are expensive, but jacking and repurposing MH370 would have been relatively cheap. Either way, I feel for the families as the passengers would be CD (too expensive to sustain for a future ransom and an early one would tip their hand) Dark and twisted thoughts, but we all know it's the real world.
Old August 29th, 2015, 05:57 PM
All well and good but parts also have inventory numbers so they know where the parts went. Part of running an airline requires meticulous record keeping. Borrowed parts have a paper trail. They are airplanes not Land Rovers.
Old August 29th, 2015, 06:01 PM
D90Overkill
David Frank
1995 ST #2615
Great, Im going to need more tinfoil. -Jeff
Metal colanders work best! ;-)
Old August 29th, 2015, 07:11 PM
I prefer nested faraday cages
Old August 29th, 2015, 07:21 PM
Bras won't cut it?
Old August 29th, 2015, 07:23 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
We're talking about Malaysia airlines here. From a country in a part of the world that operates airplanes of questionable reliability.
I've flown Malaysia. While most of my experiences have been great, I do recall flying on a 737 that had a serious vibration in engine one. Landed in Langkawi. They turned the airplane right back out.
So yes, parts are tracked with US air carriers and EU carriers. Anything in Africa, ME, SA, Russia, or Asia are questionable at times.
Bras won't cut it?
Only with underwire
Old August 29th, 2015, 07:52 PM
Originally Posted by Rocky View Post
Only with underwire
I prefer the protection of the bra contents. You may prefer the bra itself ...
Old August 29th, 2015, 08:22 PM
Personally I prefer what's supposed to be INSIDE the bra .
Old August 29th, 2015, 09:08 PM
I think we are saying the same thing.
Old August 29th, 2015, 11:24 PM
D90Overkill
David Frank
1995 ST #2615
Of course you are! You're both obviously referring to:
Old August 30th, 2015, 10:54 AM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
Each part (and assembly) has a part number and a serial number. If the part isn't a time-change item (critical and/or high wear/failure item) in most cases it will not be serially controlled (and tracked).
Proud member of the YCHJCYA2PDTHFH club.
My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
Old September 3rd, 2015, 08:57 PM
French investigators say the parts that washed ashore ARE from the Malaysia Airlines aircraft based on the serial numbers on the parts.
Old September 3rd, 2015, 09:09 PM
Are they also stating where Elvis is at the moment? Has he left the building?
Old September 3rd, 2015, 09:57 PM
They did say that Elvis was last seen running out of a Wheeling Il Walmart with a canned ham under one arm and a case of Colt 45 Malt Liquor under the other arm.
Old September 4th, 2015, 09:45 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
You know how easy it is to just throw a piece from an airplane into the ocean and spark a rumor its from MH370? They make you believe it crashed into the ocean!!!
Where's my hat!? Jason, make sure it has a brim, I need it to be somewhat fashionable.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 5th, 2015, 10:13 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Elvis was spotted in the mountain town of Timberon NM
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Snowball effect continues Uncle Douglas Misc. Chit-Chat 0 March 18th, 2011 02:01 PM
ARB locker problem continues snurp Defender Technical Discussions 1 March 12th, 2009 08:18 AM
hot stumbling, stalling.. (continues) revtor Defender Technical Discussions 4 February 10th, 2009 01:27 PM
The Rust Bucket Saga continues Emerson00 Defender Technical Discussions 13 July 21st, 2007 01:40 PM
Saga continues.... ScottYates Defender Technical Discussions 55 February 27th, 2007 05:50 PM
» Defender Registry
White
KGH
Discovery 2
MGPete
Add your Defender
