MDF Panel - Defender Source
Old May 23rd, 2012, 11:48 AM
The Dro
Dro
1988 Ninety
MDF Panel
Any idea where I can buy a 1/4" x 8' x 4' MDF (fiberboard) panel locally???
Or equivalent.
P
Old May 23rd, 2012, 12:05 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Home Depot. I use it when I make my own mouldings.
I assume you meant 4 foot by 8 foot
Old May 23rd, 2012, 12:23 PM
The Dro
Dro
1988 Ninety
I went there and was told they don't have it. I'll go to the "Professional" counter.
Fixed it... thanks!
P
Old May 23rd, 2012, 12:32 PM
tjfslaughter
thomas
Burbon
They say they don't have it because they are too lazy to help you find it.
Old May 23rd, 2012, 12:33 PM
Pedro, what are you making with MDF? It's heavy, not particularly stiff, and falls apart when wet...
Old May 23rd, 2012, 12:39 PM
tjfslaughter
thomas
Burbon
the waterproof stuff is great (usually green).
Old May 23rd, 2012, 12:56 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Pedro, if HD & Lowes give you the snub you can go try Smoot or Barrons but there will be a premium
Old May 23rd, 2012, 01:31 PM
The Dro
Dro
1988 Ninety
I agree. I asked for rivnuts and the same guy told me that they don't exist.
My RTT "cardboard" like flooring is deteriorating. It's absorbing water and is starting to bulge.
I saw another RTT that had a nice wood finish and wanted to go the same route. But instead of real wood, I want to use something that will not absorb water. ie. Plastic
I called Smoot... they will call me back. If not, I'll swing by after work.
I've never seen actual MDF in 1/4" Masonite would be the closest Ive seen.
-Jeff
Maybe I'm looking for the wrong product.
Old May 23rd, 2012, 01:36 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Get a 1/4" thick sheet of veneered marine grade plywood. Then stain to suit. Lots of options on the veneer: birdseye maple, cherry, etc. You can even purchase from Amazon:
http://www.amazon.com/Baltic-Marine-.../dp/B007TTL7VG
Old May 23rd, 2012, 01:40 PM
The Dro
Dro
1988 Ninety
That's what the other RTT had.
Old May 23rd, 2012, 02:36 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I wouldn't even worry about the veneer...just get some marine grade plywood and seal it. In a RTT application, MDF seems like the wrong product
Old May 23rd, 2012, 02:37 PM
tjfslaughter
thomas
Burbon
Hdpe is my suggestion. I can get it from some of the thermo formers I know.
Old May 23rd, 2012, 02:42 PM
The Dro
Dro
1988 Ninety
I'll give you a ring after work.
Old May 23rd, 2012, 05:21 PM
tjfslaughter
thomas
Burbon
I would talk to Laird Plastics and see what they can get you.
Old May 23rd, 2012, 11:03 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Or equivalent.
P
I bought two 1/4" x 8' x 4' sheets of marine MDF. It had to be special ordered and I had to wait a week to get it. Apparently 1/4" thickness is not common at my local lumber yard. Google "lumber yard sterling va" for a place where you can get it (~$80 per sheet? Pull my leg and I'll look for the invoice).
Now that begs the question.... What are you building?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old May 24th, 2012, 12:43 PM
The Dro
Dro
1988 Ninety
I need to repair my RTT flooring.
A few moron questions about interior trim panel removal. rustydefender Defender Technical Discussions 17 March 23rd, 2016 05:12 PM
FREE D90 Aluminum Roof Panel Roadsiderob For Sale - Parts 13 February 15th, 2006 11:38 PM
Instrument Panel wiring loykd Defender Technical Discussions 6 October 18th, 2004 10:16 AM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
94 ST Fuse Panel Cover mfreeman17 Wanted 0 June 28th, 2004 01:30 AM
