McMaster Carr order for D110 rebuild - Defender Source
Old April 9th, 2010, 11:16 PM
1 1 Pack 91280A565 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M8 Size, 110mm Length, 1.25mm Pitch, Partially Thrd, Packs of 10 Monday morning
$7.26 $7.26
2 1 Pack 91280A643 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M10 Size, 55mm Length, 1.5mm Pitch, Partially Thrd, Packs of 25 Monday morning
$10.59 $10.59
3 1 Pack 91280A660 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M10 Size, 110mm Length, 1.5mm Pitch, Partially Thrd, Packs of 10 Monday morning
$11.35 $11.35
4 1 Pack 91280A712 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M12 Size, 20mm Length, 1.75mm Pitch, Fully Threaded, Packs of 25 Monday morning
$9.24 $9.24
5 1 Pack 91280A740 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M12 Size, 110mm Length, 1.75mm Pitch, Partially Thrd, Packs of 5 Monday morning
$9.23 $9.23
6 2 Packs 91801A315 Metric 316 SS Flat Head Phil Machine Screw M6 Size, 20mm Length, 1mm Pitch, Packs of 10 Monday morning
$4.90 $9.80
7 1 Pack 93935A335 Metric Type 316 Stainless Steel Thin Hex Nut M6 Size, 1mm Pitch, 10mm Width, 3.2mm Height, Packs of 50 Monday morning
$5.60 $5.60
8 1 Pack 90965A170 Metric DIN 125 Type 316 SS Flat Washer M6 Screw Size, 12mm OD, 1.4mm-1.8mm Thick, Packs of 100 Monday morning
$6.86 $6.86
9 1 Pack 92153A426 Metric Type 316 SS Split Lock Washer M6 Screw Size, 11.8mm OD, 1.5mm min Thick, Packs of 100 Monday morning
$6.77 $6.77
10 1 Pack 90591A161 Metric Zinc-Plated Steel Hex Nut Class 8, M8 Size, 1.25mm Pitch, 13mm W, 6.5mm H, Packs of 100 Monday morning
$4.83 $4.83
11 1 Pack 90591A171 Metric Zinc-Plated Steel Hex Nut Class 8, M10 Size, 1.5mm Pitch, 17mm W, 8mm H, Packs of 100 Monday morning
$8.37 $8.37
12 1 Pack 90591A181 Metric Zinc-Plated Steel Hex Nut Class 8, M12 Size, 1.75mm Pitch, 19mm W, 10mm H, Packs of 50 Monday morning
$8.19 $8.19
13 1 Each 98018A424 Metric Zinc-Plated Steel Flat Washer Asst 9 Screw Sizes, 825 Pieces in Compartmented Box Monday morning
$59.43 $59.43
14 1 Each 91170A109 Metric Split Lock Washer Assortment Black Steel, 10 Screw Szs, 755 Pcs in Plastic Case Monday morning
$45.28 $45.28
15 1 Pack 91280A634 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M10 Size, 30mm Length, 1.5mm Pitch, Fully Threaded, Packs of 25 Monday morning
$7.80 $7.80
Merchandise $210.60
Thought it might help someone to have the numbers handy.
These are for the "big" bolts. I bought an assortment for the small ones. M6 and down. Same thing for sheet metal screws. I bought one small stainless set and three $3 sets at wal-mart.
Ron
Old April 9th, 2010, 11:42 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
I am already on my 3rd order because I keep finding other bolts I will need as I took everything apart. All total close to $300-350. Wish I had this list before. Would have saved multiple orders.
MUDSUX
Old April 10th, 2010, 12:07 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
You can get small quantities on boltdepot.com
Sometimes you just need a couple of bolts
and McMaster will sell a pack of 25.
- Charles Eames
Old April 10th, 2010, 12:16 AM
Like everything else, I have one of everything plus a couple spare. My theory is time is valuable, bolts are cheap.
Ron
BTW, I ordered the lock washer assortment in black because that is all they sell for an assortment.
I should also add, there is a typo, the assortment has M10 and down, but these are the ones not in the assortment you should need.
This is the assortment I bought:
Part Number: 98735A040 $69.14 Each
Assortments
Metric Class 8.8 Zinc-Plated Steel Standard Hex (465 Piece)
Assortment Contents
Includes DIN 933 fully threaded hex head screws and DIN 934 hex nuts.
Hex Head Cap Screws Included
25 each: M4 x 12, 16, 20, 25; 20 each: M6 x 12, 16, 20, 30, 40; 15 each: M8 x 12, 16, 30, 40, 50; 10 each: M10 x 20, 30, 40, 50.
Hex Nuts Included
50 each: M4, M6; 25 each: M8, M10.
Assortment Case
Furnished in a 13-1/8" Lg. x 9" Wd. X 2-5/16" Dp. plastic case.
Notes
A bottle of lock thread sealant is included.
Old April 10th, 2010, 01:37 AM
I must have placed 10 order with them each time I rebuilt a truck. Someday I'll really figure out what is required.
Old April 10th, 2010, 01:39 AM
This list is based off what you gave me as far as what to order plus a few more things I added (I like assortments because they come in boxes).
Old April 10th, 2010, 07:21 AM
What I mean is I want to make a "map" of the chassis so that you can just visually look up what you want.
Old April 10th, 2010, 07:59 PM
I see. That would be awesome.
Ron
Old April 13th, 2010, 08:30 PM
I got the order. If I were going to do it again, I would skip the assortments and just order M6, M8 and M10 washers. I also need to order M6, M8 and M10 fender washers and the M6 stainless nuts are the thin jam nuts. I can't find the right fender washers on mcmaster carr though. M6 from LR appear to be about 22 or 23mm and mcmaster carr sells 18mm for fender washers.
Ron
110, d110, master, rebuild
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
Ideas for CVC's "banana flambe" rebuild evilfij Misc. Chit-Chat 24 September 23rd, 2005 01:10 PM
LT230 needing rebuild Abrooks For Sale - Parts 15 October 4th, 2004 10:14 AM
where to find rebuild manual for 4.0L? Chris Cox Defender Technical Discussions 0 January 27th, 2004 09:36 PM
