Mantec snorkel through wing on a NAS truck? - Defender Source
Old January 14th, 2009, 10:54 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Has anyone mounted the Non NAS Mantec snorkel to a NAS truck? Specifically this is the standard through wing body panel snorkel (not the one that passes through the wing top plate). If so, can you take some pictures and post up? Looking at mounting one of these in the existing place of my southdown snorkel to reduce the stainless bling.
Old January 14th, 2009, 12:06 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
That would be too easy...
I was considering it though.
Old January 14th, 2009, 12:42 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
A couple of my friends have southdown snorkels for their D2... they used a spray on bedliner (aerosol style) to paint it... worked rather well... one of them ended up chipping off a bit, so just another quick spray and it was back to black..
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old January 14th, 2009, 02:38 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Now your just changing things for the sake of changing things! Spend more on diesel and come wheel with us.
I have that snorkel BTW. I don't think you want to make the switch, your install is nice and clean.
Old January 14th, 2009, 02:59 PM
I hear you.
Old January 14th, 2009, 09:46 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Just did one because the customer wanted a raised air intake, but did not want it on the drivers side because he felt it blocked his vision. So we modified a Tdi intake to the V8.
http://www.eastcoastrover.com/CMC151.html
Email:
Old January 15th, 2009, 07:52 AM
pmd's Avatar
pmd
Paul Dandini
None :-(
Dave,
If you are looking for the part that attaches to the side of the panel - I have a new one that I have no plans for - lmk.
Looks like this:
Old January 15th, 2009, 08:07 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Thanks Paul, no I'm not. Just looking to replace my existing Southdown with some more "authentic" and still use the hole i put through the wing 5 years ago.
KB is right. I need to get off my arse and wheel.
Thanks Mike. Do you happen to recall the outer diameter of the snorkel where it enters the wing?
Old January 15th, 2009, 08:21 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I've been out 3 times in the past 6 weekends, let me know if you can sneak away for a day. 25th is the next time I plan on going out.
Old January 15th, 2009, 08:32 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
kevin are you going out with the SNH boys?
Old January 15th, 2009, 08:36 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Yep.
Old January 15th, 2009, 09:05 AM
ECR's Avatar
ECR
Sorry, I don't and the truck is gone now.
I never liked the side fender intake myself. It kind of sticks out there and if I had one it would have been flattened by a tree while off roading pretty quickly. I like the fender top units myself, just my .02
Email:
Old January 15th, 2009, 09:19 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
AB is in the process of bringing the Genuine cores in.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old January 15th, 2009, 09:21 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
The main pipe is 2.825" and steps down to 2.515"under the wing where the flex tube goes over it. I had to cut a bit off of the bottom of the pipe in order to be able to snake it around the Mt. Mansfield heater. The very top of the flex hose and clamp to secure it are just outside of the wing on mine but remember I am adapting a Defender unit to a series with a Daihatsu motor.
Last weekend.
Old January 15th, 2009, 10:14 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Don't want to hijack the thread Dave but do you guys think that a snorkel restricts HP on the TDI at all? I would like one but then my truck will not fit in my garage. it makes it in by about 1/8 of an inch right now.
Legend in My Own Mind.
Old January 15th, 2009, 10:16 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Mine is no higher than the roof line.
Old January 15th, 2009, 10:43 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I had a similar thinig with my Td5 110 here, (and my old 90), where i've got a rollcage fitted, the front upright support bars (that bolt to the bulkhead) are in the way to easily fit that stupid little plastic ait intake thing.
So i just bit the bullet and cut a hole down through the wing top and connected the pipe directly to the air box.
Just make sure you measure several times and get it accurate. I used my die-grinder to open the hole up a bit so it fitted snugly (with some of that push on "edging" stuff)
http://img.photobucket.com/albums/v1...m/HPIM5854.jpg
http://img.photobucket.com/albums/v1...m/HPIM5855.jpg
http://img.photobucket.com/albums/v1...m/HPIM5856.jpg
http://img.photobucket.com/albums/v1...m/HPIM5857.jpg
http://img.photobucket.com/albums/v1...m/HPIM5878.jpg
http://img.photobucket.com/albums/v1...m/000_0005.jpg
Old January 15th, 2009, 01:39 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Thanks guys. Appreciate the responses.
Mike Smith, I'm definitely avoiding the "side of the fender" mount. Was just going to use the existing hole for my southdown snorkel (through top of fender).
Randy, tough to say. I've had one from the start. I could try running with it disconnected for a while without a probelm and give you some info.
KB, we can chat about it if you come over Sat.
Old January 15th, 2009, 04:06 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
off topic, but I just saw that truck in person and it is absolutely beautiful.
because six cylinders will take us farther than any president
Old January 15th, 2009, 04:27 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
If you want me to take measurements, just shout.
I've got the original Td5 "through the side of the fender metal jobbie" as well, if you want piccies/dimensions.
mantec, nas, snorkel, wing
Mantec Snorkel attachment UpnOver Defender Technical Discussions 7 December 8th, 2013 10:59 PM
'97 Nas D90 Sw Le #008/300 Classic Rover For Sale - Vehicles 19 November 28th, 2013 08:53 AM
A Great Read... CDN90 Misc. Chit-Chat 6 December 16th, 2009 12:25 PM
Mantec Defender snorkel for sale k4rovers For Sale - Parts 4 December 12th, 2006 12:37 PM
Mantec Snorkel Install Question ronward Defender Technical Discussions 2 April 1st, 2005 08:16 AM
