Making Desk Clock From Truck Clock - Defender Source
Old February 6th, 2016, 09:31 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
Alright folks, I'm only passably good at electrical work, usually it involves more blue splitters than I'd care to admit, so help me out here.
I just replaced my clock for a tach in the truck, and I'd love to turn the truck clock into a desk clock. I'm gonna make or buy a nice wood housing for it. The question is, how do I wire up a 12v clock to either a wall outlet or AA batteries?
Seafoam Green 1983 110 3 Door - sometimes SW, current ST.
Spent it's working years in France, it's mid-life crisis in The Hamptons, and now its golden years in Washington, D.C.
Old February 6th, 2016, 09:35 PM
12v wall wart if you don't mind the cord. Battery wise I'm not sure how long they would last.
Old February 7th, 2016, 08:06 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I've thought of buying a cheap clock that runs off of AA's and using the inners with an early One Ten clock I picked up here in the forum.
Old February 7th, 2016, 08:14 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
So for a wall wart like this:
http://www.amazon.com/Wall-Adapter-P.../dp/B006GEPUYA
Do I just splice the cable? Does it have positive and ground cables if you chop off the connector?
Old February 7th, 2016, 08:18 AM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Originally Posted by DPdotCOM View Post
So for a wall wart like this: http://www.amazon.com/Wall-Adapter-P.../dp/B006GEPUYA Do I just splice the cable? Does it have positive and ground cables if you chop off the connector?
That would work just fine. Take a multimeter and test to see what lead is 12VDC.
Old February 7th, 2016, 08:23 AM
1of40's Avatar
1of40
1of40
http://forums.pelicanparts.com/porsc...esk-clock.html
Old February 7th, 2016, 11:23 AM
kimberly's Avatar
kimberly
kimberly
1957 LR S1 88"
good project! subscribe
i drive a series 1 because even defender drivers need heroes
Old February 7th, 2016, 02:28 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
I Made a faceplate and stand for an old aircraft clock with the CNC, and just used a power supply for the backlight, the clock itself is an 8 day mechanical movement, ill see if I can find some photos
Old February 7th, 2016, 04:35 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
Ah, good call. Maybe I should just CNC something at the library (god I love living in the future). A brushed metal stand could be really nice.
Old February 7th, 2016, 07:31 PM
PabloCocito
Pablo Cocito
this is V1.0 so its pretty rough all around, but the idea is the same, i cant seem to find a photo of the finished stand though..
Old February 9th, 2016, 10:59 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
Alright, step one complete. Wall wart purchased, wires split, connectors added, and success!
Old February 9th, 2016, 11:08 PM
RBBailey
RBBailey
1965 IIa
Dang! You beat me to it! I had this idea a few months ago...
...Good idea!
The metal stand looks great. We should keep this as a running thread for all the clocks that have been turned into desk clocks.
Project:
1965 IIa SWB
Old February 10th, 2016, 08:09 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
Ok, dumb question. How does the clock get power to keep ticking AND another be backlit? Is it a voltage issue? That when the dash lights are off, the clock still gets a tiny amount of voltage, but on its just served full power? Not a big deal, but if I have the option to put in a switch for backlit or not, that'd be sweet!
Old February 10th, 2016, 09:09 AM
The Dro
Dro
1988 Ninety
Run two wires from the Positive. Add a switch to the one for the light.
But since this is a Rover part... I'd be careful so you don't burn down the house.
Old February 10th, 2016, 02:19 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
Is the light a separate lead on the clock? I could swear I only pulled two leads off. Then again, maybe my clock was never lit? The dash light switch has been burnt out for most of the time i've owned the truck and only fixed it a couple weeks ago.
Old February 10th, 2016, 04:18 PM
PabloCocito
Pablo Cocito
Snapped a few pictures
ID:	142067   Click image for larger version
Old February 10th, 2016, 04:19 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
oh MAN that's slick. Surprised it doesn't tip over. Love the whole look of that though
Old February 10th, 2016, 05:55 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
What's the first thing to do during an EP?
Wind the clock...
Old February 15th, 2016, 11:13 AM
1of40's Avatar
1of40
1of40
Found a nice early One Ten VDO clock in my box of spares that might make desk/wall clock. $45
Old March 1st, 2016, 08:06 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Thoughts on power supplies? Does it need to be 12vdc or will 9 or even 6vdc keep time?
View from my desk... WD90 Misc. Chit-Chat 56 April 8th, 2013 01:58 PM
Jotto Desk Install (D90) CDN90 Defender Technical Discussions 4 March 26th, 2010 12:12 PM
D90 rock crawling on my desk! LenB Misc. Chit-Chat 3 June 28th, 2008 01:11 PM
Jotto Desk - Mounts from Offroadguides.com JohnnyK The Vendors Loft 0 March 22nd, 2004 06:40 PM
