Magunson Supercharger - Defender Source
Old October 19th, 2008, 11:13 AM
bstraw's Avatar
bstraw
Byron Straw
1994 POE/ST
I bought this in working condition all parts there and am not sure I want to use it. Main reason it is set up for a serpentine belt system and I have the v belt system. Also I am looking for better gas mileage and not sure this is going to do it. Anyone have a realistic idea of what this is worth? Any Help would be greatly appreciated and I thought I would ask here before I posted in the For Sale section.
Old October 20th, 2008, 10:38 AM
Is it set up for GEMS or for 14CUX? What was it on originally?
Old October 23rd, 2008, 01:30 PM
zimm's Avatar
zimm
bart
anyone moves..... #238 sold
superchargers dont give you the option to "stay out of it" like a turbo does, so im guessing better mpg aint gonna happen. more air at all rpms means more fuel at all rpms, whether you need that power or not. that having been said, if youre at 12mpg stock, whats 10 or 11 matter? toss it on!
Old October 23rd, 2008, 01:36 PM
MEUSOC
BRYAN
NAS 110, 95 ST
I actually got better mileage in a toyota after I installed a trd supercharger-made it a more efficient air pump!
Old October 23rd, 2008, 02:52 PM
minorthreat
Lance
1997 LE, 1997 Black ST
Don't use it. Sell it and buy some useful mods for your Defender.
Old October 23rd, 2008, 03:13 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Most systems have inlet side bypass valves that open at light throttle settings, essentially venting the boost pressure that is not required back to the inlet side of the supercharger. This takes care of the problem of having to dump more fuel all the time, but since a supercharger is always being spun by the crank (unless you take the movie approach and have a switch for your supercharger ) , it is always putting an increased load on the engine, and therefore requires more fuel to support that additional load (though it is minor).
~Scott T.
'95 D-90 ST - AA Yellow
Old October 25th, 2008, 10:20 AM
zimm's Avatar
zimm
bart
i think read 13%+/- for the efficiency difference between a turbo and supercharger. being the drag is a coefficient of friction on the accessory system at all times im guessing its significant, and will cost you 13% at low rpms, where the supercharger isnt in its ideal airflow range.
is that kit a turbo vane style or a eaton unit? back in the stangbanging days, the eatons produced a steady 8psi from a low rpm where the paxtons and vortecs had to spool up. the eaton units were more pratical for day to day, stoplight to stoplight, but lacked topend.
Old October 25th, 2008, 08:06 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I believe it is a twin screw Whipple design..
~Scott T.
3.9 with Supercharger set up budz Defender Technical Discussions 11 June 29th, 2009 10:54 PM
Supercharger Whine/Noise gtg067i Defender Technical Discussions 1 December 23rd, 2006 06:29 AM
TVR Supercharger for Rover V8 Doug Misc. Chit-Chat 2 January 27th, 2006 04:43 PM
Rimmer Supercharger, complete. Also side fuel tank. Tom Fitzgerald For Sale - Parts 14 December 12th, 2005 08:09 PM
Supercharger jorge Defender Technical Discussions 2 November 20th, 2005 07:21 PM
