Madman Engine Monitoring Systems Defendersource discount - Page 5 - Defender Source
Join the Defender Source Community Today
Old March 28th, 2016, 12:26 PM
east high's Avatar
east high
Gerad Davis
1967/s2a 88
Originally Posted by DailyDrivenDefende View Post
Along with the EMS, what else did you guys buy to complete the project from Madman?
I am getting ready to pull the trigger myself.
I ordered the connector kit for my motor.
Old March 29th, 2016, 11:23 AM
east high's Avatar
east high
Gerad Davis
1967/s2a 88
Woke up to a handful of MadMan emails explaining payment steps. I followed them - contacted my bank just in case - and was able to successfully make payment.
Old March 29th, 2016, 11:43 AM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
I was able to pay w/ a CC without any issues?
Old March 29th, 2016, 12:09 PM
He fixed the issue this morning.
Old March 29th, 2016, 01:05 PM
RBBailey
RBBailey
1965 IIa
In my own little world, I'm imagining it would be easy to get an LED to come on when fluid level is low by using one of these:
MadMan - M10x1 Brass Water Level Sensing Plug
But.... I'll have to do some research to figure this out. Any thoughts?
Project:
1965 IIa SWB
Old March 29th, 2016, 01:12 PM
The EMS have a built in unit to detect low level with one of those. That version is for a Disco 2. There are other options for other setups. The "normal" method for people with plastic coolant tanks is two screws into the tank, which are supplied with the EMS. If you don't have the plastic coolant tank, the next best option is the plastic 1/2" BSP version to go into the rad.
If you don't have an EMS, they sell a dedicated coolant level detector. http://www.madman.co.za/index.php/pr...-detector-v2-0
Old March 31st, 2016, 01:32 PM
mdcoa's Avatar
mdcoa
Bill
1995 Discovery
Originally Posted by Red90 View Post
That was just for before the discount code was active.
Yeah I totally missed that part too and waited a couple days for payment instructions....drrr.
Madman EMS1 installed and working great--tonight I'll fine tune the units and start setting alarm levels. A very slick system.
Old March 31st, 2016, 07:11 PM
RBBailey
RBBailey
1965 IIa
The EMS have a built in unit to detect low level with one of those. That version is for a Disco 2. There are other options for other setups. The "normal" method for people with plastic coolant tanks is two screws into the tank, which are supplied with the EMS. If you don't have the plastic coolant tank, the next best option is the plastic 1/2" BSP version to go into the rad. If you don't have an EMS, they sell a dedicated coolant level detector. http://www.madman.co.za/index.php/pr...-detector-v2-0
Yeah. I saw that. In my make believe world I was thinking a monitor at the thermostat would be good. And I could pretty easily build a light that would go OFF when water is low, but I'm not smart enough to figure out the circuit for one that will be off, then go on when water is low at thermostat.
I do have a plastic tank now, and am looking to put a float type in there.
Project:
1965 IIa SWB
Old March 31st, 2016, 07:20 PM
Sensing if there is coolant or not requires electronics. You can't just stick voltage across the engine making a circuit through the coolant.....
Old March 31st, 2016, 07:49 PM
RBBailey
RBBailey
1965 IIa
Right.
Project:
1965 IIa SWB
Old March 31st, 2016, 08:01 PM
Originally Posted by RBBailey View Post
Right.
when coolant is empty, the sensor will read way low. easiest and most reliable way to tell.
Old April 9th, 2016, 04:49 PM
Chucked mine on today. Put it in the middle gauge spot, replacing the coolant temperature gauge. Hooked up coolant temperature, EGT and coolant level. Will do the rest later.
Works nice. Easy to program. Easy to read.
ID:	146847   Click image for larger version
ID:	146849   Click image for larger version
Old April 24th, 2016, 12:04 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Here is a pic of another MadMan installation (RHD).
About to do mine (LHD). But rather than in the center of the display, would it not be easier to get to on the LH side?
Eric.
Old April 24th, 2016, 12:25 PM
Eric.
Should be the same amount of work to install in any of the three spots. I think that any of the spots will work visually and functionally.
One thing I noticed is the audible alarm is not loud enough to hear in a Defender.... If it is placed elsewhere that you would not immediately see the flashing light and alarm, I would add a separate beeper or wire to one of the unused dash lights.
Old July 23rd, 2016, 08:15 PM
93' NAS 110- #234
so I finally got around to installing my EMS today. Very easy install, but I'm getting an out of range flashing error on the coolant temp when I set it to Fahrenheit. It reads fine on Celsius. I've set the coolant temp menu for sender to vdo150 to replace my vdo gauge. I have the vdo sender 323-088. anybody else have this issue with this sender?
Mark Kellgren
KM4BOR
Old July 23rd, 2016, 08:30 PM
mdcoa's Avatar
mdcoa
Bill
1995 Discovery
It's been a couple months since I installed mine, but if I recall correctly, the system is set up so that the ranges are the same irrespective of your chosen temperature system--i.e., they're the same numerals, so a perfectly healthy engine that reads within the default C range will be way out of range once your temperature system selection changes the boiling point from 100 to 212.
So just reset the range parameters--it's in the little paper thing that came with the gauge (which I didn't read until I realized it bad completely different information from the install instruction .pdf I found online . . .)
Please PM me if you want me to go run out to the truck and have a look at the setup guide, but I'm about 94% sure this is right.
Old July 23rd, 2016, 08:54 PM
93' NAS 110- #234
Thanks. I figured it out, but it was the "span" setting. it had to be set to the sender range, not the vdo gauge range I had been plugging in for the gauge I was replacing.
Mark Kellgren
KM4BOR
Old July 23rd, 2016, 09:15 PM
mdcoa's Avatar
mdcoa
Bill
1995 Discovery
Glad you figured it out, and my apologies for totally misunderstanding the issue . . .
Old July 23rd, 2016, 09:52 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
My values are always changing depending on which accessorize I turn on.. Heater, wiper, blinker, etc. if I plug it in directly to the battery then it's fine, but then it's not a switched power source.. Where should I wire the gauge to? And also, the relay cable isn't triggering the fan when it says it should be.(it works if I provide the relay switch cable with current) Does the purple go directly to the relay switched cable?
Thanks!
Old July 23rd, 2016, 10:03 PM
mdcoa's Avatar
mdcoa
Bill
1995 Discovery
Thanks!
I wired my gauge's positive wire to an add-a-circuit thingmo, which I plugged into my main fuse block--one something like this: https://www.amazon.com/Pico-0956PT-B...=add+a+circuit
I just played around until I found a fuse circuit that was already switched.
The values change depending on what I have on--headlights and AC affect the readings most, and I may reset my alarm values so my wife doesn't panic when the truck is idling with the AC on and the voltage drops low enough to sound the alarm.
As for the purple wire, I didn't hook mine to anything--the purble wire, as I understand it, is just to run an additional alarm if you want to. So if the stock EMS alarm isn't loud enough/visible enough, you can use the purple wire to trigger a relay for an air-raid siren or a dash-mounted strobe light.
-Bill
defender, disco, engine
Madman EMS2 EGT/Boost/Temp Gauge BlackField Wanted 22 November 28th, 2015 12:10 PM
DefenderSource.com Announcement Andy R Misc. Chit-Chat 29 March 26th, 2013 01:06 PM
Moving to DefenderSource.com Andy R Community News & Announcements 0 March 21st, 2013 11:26 AM
SmarTire Pressure Monitoring System RyanS For Sale - Parts 3 March 9th, 2008 03:40 PM
» Defender Registry
#304
TRS
95 RRC
WeBeCinYa
Add your Defender
