Lube Suggestions - Defender Source
Old January 14th, 2004, 11:25 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Lube Suggestions
OK. What do you guys recommend for oil, etc.. in my d-90. What grands are good? What type? What weights? I have no clue. Now The 300tdi is new along with a new r380 and new lt-230.
what should I use in each? Also, what about the diffs? Thanks guys.
Old January 14th, 2004, 11:42 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Lube Suggestions
Had a good experience with both KY and Astroglide
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 14th, 2004, 11:47 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Nice one. I set myself up for that..
Old January 14th, 2004, 12:05 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Man, I am on top of it this morning! I have had good experience with synthetic atf in the r380, royal purple in the diffs and transfercase, $$ but good. I wish I rememberd weight but you can pull that from your manual. I also use Diesel 20w 40?? In the tdi. I am not totally sure on that one but I do not use synthetic. I got word it was not the best for TDi, no personal experience with that so not sure it is accurate. Hope it helps a little.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 14th, 2004, 01:08 PM
I have always heard that for initial engine break in period its bad to use syn motor oil because it is too "slick" that a regurlar dyno is bettter because it always all the engine componets to "mate" together. Not sure about the case and tranny. I use Mobil 1 everywhere but the tranny. i have redline ATF in there.
Old January 14th, 2004, 01:22 PM
I use Mobil one in the T-case and tranny, Theses are the only 2 smooth operating components of the 90 with the outside temp at -7 this morning.
Old January 14th, 2004, 06:40 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
you need to move... 73 and sunny here
Insert pithy quote here.
Old January 19th, 2004, 07:56 AM
Hey, it was nearly 30 out yesterday and it seemed like a heatwave. I think LA is a little too $$$$ for me.
Looking for Front Seat Suggestions smenzel Defender Technical Discussions 39 February 26th, 2006 07:55 PM
no spark suggestions? mattdh Defender Technical Discussions 12 April 25th, 2005 09:59 PM
Lube Fittings Dfndr90 Defender Technical Discussions 4 October 14th, 2004 08:12 AM
Just failed an emissions test, suggestions? Hans Defender Technical Discussions 6 October 11th, 2004 12:12 AM
Suggestions from you gadget people... dmarchand Misc. Chit-Chat 45 May 3rd, 2004 01:38 PM
