LT77 crush washer part numbers - Defender Source
Old October 18th, 2015, 07:39 AM
wanabewheelin's Avatar
wanabewheelin
Michael Sword
1989 110 200TDI, RHD
Pulled the covers off my LT230, found at least one reason the rear cover was leaking . . . One of the bolts was sticking out half an inch. So upon reassembly found I had the same issue, bolt was just too long, cut to size and all good.
LT77 crush washers, need two, larger is on the bottom and hold a plastic mesh screen in place and the second is on the side, not the fill plug mind you.
Looking for part numbers that cross reference to something that I can pick up at a local parts store.
part
Orange Crush (Kermit) kenn73 Misc. Chit-Chat 5 July 14th, 2016 09:39 AM
Installing anti-crush spacer into frame Landy_Andy Defender Technical Discussions 3 May 5th, 2015 01:44 AM
95 RRC Rubber Crush Can Covers Toughy Wanted 0 December 9th, 2014 11:53 PM
Wheel spacers and Crush can covers Toughy Wanted 0 May 1st, 2014 12:14 AM
Intermediate Shaft Crush Sleeve - Different Ones? Wolf Fabrication Defender Technical Discussions 0 September 13th, 2010 05:16 PM
