LT230 noise? - Defender Source
Old March 18th, 2005, 07:19 PM
Chaucer
Will
93 110 | 97 90
LT230 noise?
Hey all,
I've never driven another D-90, so I don't know if what I'm hearing is normal or not.
From about 20mph and up, there's a high-pitched whine coming (I believe) from the transfer case. If I lift my foot off the gas pedal, the noise instantly goes away. If I keep my foot off the gas, the rig starts to slow down and the noise comes back. If I put my foot back on the gas, the noise comes back.
Is this normal or does it sound like transfer case is in need of repair?
Old March 18th, 2005, 08:13 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Mine does pretty much the same thing and has for 3 years (ever since I've owned it). Keep the fluid topped up and you should be fine.
Doug W
Old March 18th, 2005, 08:52 PM
Yes, the transfer cases do make audible noise.
Old March 19th, 2005, 01:28 PM
Chaucer
Will
93 110 | 97 90
OK, thanks guys. Mine has made the noise for the 3+ years I've owned it. Just wanted to make sure it was either normal (and just live with it). Or...if it wasn't normal; fixed it.
Old March 19th, 2005, 01:36 PM
Hey guys what fluid are you running in it? I am wondering if it has anything to do with the noise, on my first T-case I don't know what was in it when I got mine, but it did whine from time to time, then I deained it and refilled it with Mobile one and it never made a noise again. I run Mobile one in the new case and it's quiet as a mouse.
Old March 19th, 2005, 02:59 PM
Chaucer
Will
93 110 | 97 90
Don't know what was in it when I bought it, but I switched it out to Amsoil SAE 80W-90 Synthetic Gear Lube
lt230
engine noise. Campbell Defender Technical Discussions 31 October 3rd, 2005 10:34 AM
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
Lt230 & Lt95 tbmcneill Defender Technical Discussions 4 February 21st, 2004 04:23 AM
