LR4 Brake Advice requested - Defender Source
Old June 4th, 2017, 08:03 AM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Going to do pads and rotors, front and rear on the LR4.
Anything tricky to look out for? Look pretty straightforward in the parts diagrams.
Remove caliper and pads, remove setscrew, remove and replace rotor, reassemble.
Truck is going in for some warranty work, so will have LR do a brake fluid flush and refill, it is at specified mileage for this.
KGH - “Stinky LR diesel” Defender Snob
Old June 4th, 2017, 09:14 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Sensors? Don't know if they're separate or not.
Old June 4th, 2017, 11:20 AM
Broncoduecer's Avatar
Broncoduecer
peter
D90
http://media.disco3.co.uk/gallery/al...le_V1.4sml.pdf
This was really helpful when I did my fronts. The rear is a little more work with the parking brake.
Buy new set screws. Mine weren't reusable.
https://www.landrovermerriamparts.com Had really good genuine prices.
And yeah get new sensors. One front and one rear (at least on LR3)
Old June 4th, 2017, 08:05 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Not sure if the lr4 is the same as the lr3, but if it is, make sure the rear parking actuator is bed in correctly.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old June 6th, 2017, 05:10 AM
KGH's Avatar
KGH
Real Name
Land Rover Merriam beats Land Rover International with prices, thanks.
Will give a look at UK but shipping will prob negate savings.
By sensor, do you all mean wear indicator?
Old June 6th, 2017, 06:25 AM
1of40's Avatar
1of40
1of40
Yes, iirc they are not reusable. I see they are sold separately.
------ Follow up post added June 6th, 2017 06:31 AM ------
Originally Posted by Broncoduecer View Post
http://media.disco3.co.uk/gallery/al...le_V1.4sml.pdf This was really helpful when I did my fronts. The rear is a little more work with the parking brake. Buy new set screws. Mine weren't reusable. https://www.landrovermerriamparts.com Had really good genuine prices. And yeah get new sensors. One front and one rear (at least on LR3)
Their site says parts ship in 3-7 days. Wow! What has been your experience?
Old June 9th, 2017, 12:40 AM
You need to release the parking brake set on the rears, then retighten it correctly after. Basically the only thing on the brake job that's a small pita. You need to align the hole on the brake rotor with the set wheel then loosen, on reassembly tighten till it's tight then back off 3-4 clicks. It's in the repair manual.
I go OEM pads and whatever rotors (not the cheapest stuff but middle of the road, it's just iron anyways, no magic there.
95' D90 - daily driver..
advice, brake, lr4
Range Rover, LR3, LR4 Buying Advice Hinckley423 Misc. Chit-Chat 13 December 29th, 2011 10:44 AM
Advice on fitting a US-seven pin and electric brake controller onto a '83 110? turbodave Defender Technical Discussions 4 June 25th, 2009 02:48 PM
Parking brake retrofit advice Abrooks Defender Technical Discussions 5 April 13th, 2009 11:39 PM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
