LR4 2010-2012 Feedback? - Defender Source
Old January 15th, 2018, 06:32 PM
sandman913's Avatar
sandman913
1986 Land Rover 110 CSW
Anybody have one? Looking at these as an option. Thanks.
Old January 15th, 2018, 08:12 PM
bjf's Avatar
bjf
barry f
94 ST #395
I have a 2010. I have 80,000 miles on it now but I got it with 40,000 about 4 years ago.
Issues:
Eats brakes - every 12000 miles
Control arm bushing at 50000 miles
Starter went at 75,000 miles.
Alarm kept going off. Replaced a good switch and now it's good.
Otherwise it's all good.
Old January 15th, 2018, 08:51 PM
Grover's Avatar
Grover
Do these have the 5.0 without the dipstick?
Old January 15th, 2018, 08:54 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Mine is 2012. 38K on it. Getting ready to trade by Aug, as that is when warranty expires. Love it. HSE LUX.
No dipstick, nav seems like something from the 90’s, but not as bad as GM from that year!
KGH - “Stinky LR diesel” Defender Snob
Old January 15th, 2018, 10:07 PM
sjpin
Scott P
I have a 2011 with 70K and love it. I agree with Barry on the brakes.
Old January 15th, 2018, 10:17 PM
sandman913's Avatar
sandman913
appreciate the feedback. thanks.
Old January 16th, 2018, 11:03 AM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
2012 HSE V8. Bought it CPO. Love it. 75k miles. It is the modern day defender. Agree with the above issues.
Old January 16th, 2018, 11:23 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
The LR4 is by far the best Land Rover in the post round headlight era. It might be the last one to, but that's for another discussion.
Mine is a 2011 bought new and currently has 140,000 miles. Have replaced brakes 3-4 times, controls arms twice. have had zero issues, knock wood, save for a climate control fan.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old January 16th, 2018, 11:39 AM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Thanks, guys, thinking about picking up one of these, as well. Do you just get brakes done at any old shop? There's a super owned family garage within walking distance of my house and they do my 2014 Audi brakes for 1k (rotors/pads). Wondering if I could do the same with an LR4.
-Ren Ching
Old January 16th, 2018, 11:42 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
The dealer will charge double that for LR4 brakes. Definitely go with an indy. I do.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old January 16th, 2018, 11:49 AM
D90884's Avatar
D90884
Jon
1994 Defender 90 #884
I have a ‘12 HSE LUX. We bought it with 74k miles on it a year ago and we now have about 93k on it. Its our daily driver and has been driven from New England to Florida and back and it’s towed my D90 on a car trailer. Zero issues except an intermittent heated steering wheel and one bad brake pad sensor wire. Other than these very minor issues it has been terrific and very reliable.
Old January 16th, 2018, 12:03 PM
bjf's Avatar
bjf
barry f
94 ST #395
When you do brakes go genuine. I once did non genuine and they made noise the entire time.
Old January 16th, 2018, 12:11 PM
roverguy's Avatar
roverguy
Robert
1995 RRC
Anyone have the timing chain issues?
1965 IIa 88
1995 RRC 25th Anniversary
98 Discovery LE7
2000 DII (SOLD)
Old January 16th, 2018, 12:25 PM
roverguy2's Avatar
roverguy2
Brian Morton
1991 Defender 110 "Blanca"
Sold my 2015 and it had brake issues from new so no changes for newer models as far as brakes go.
Dealer tried to stick it to us when it had less than 12K miles for brake vibration in fronts. They turned the rotors but never replaced the pads under warranty. That and tire wear was the reason my wife wanted to sell the truck so quickly. Otherwise one of the best Rovers I've ever owned.
Old January 16th, 2018, 01:06 PM
michael67's Avatar
michael67
Michael White
110 Tdi
I've got a 2012 with 125k miles that I bought in 2012 with 13k miles. Bought the 100,000 mile extended warranty and work done under that:
- Rear hatch solenoid
- Control arm bushings
- Water pump (was leaking)
- One of two high pressure fuel pumps failed
- Window control auto-up needed to be reset several times
Post warranty:
- Air compressor failed while in Ohio, drove back low-rider style
- Parking sensors falsing
- Parking brake won't release once set
- Rear hatch solenoid acting up again but still opens after a few presses
Tire wear is not bad given truck weight if you buy good tires. Brake wear isn't bad - I've replaced the front pads twice and the front rotors once. I replaced the rear rotors & pads once as one pad wore prematurely and ate the rotor (LR couldn't find a reason).
Old January 16th, 2018, 02:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
I do feel the motor is loud. Was worried it was the timing chain but my shop said the 5.0s have loud injectors.
Old January 17th, 2018, 08:23 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
We’ve done a few of the timing chain guides on these. I think it’s ‘10 and ‘11 and some ‘12 that have the older style guides that wear out prematurely. Make sure that’s been done if you are buying one used.
Old January 17th, 2018, 08:39 PM
bjf's Avatar
bjf
barry f
94 ST #395
How can you tell if they are wearing? My shop said if you have issues they throw codes.
Old January 17th, 2018, 08:44 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I think you can see one of the chains through the oil fill cap and you should be able to see if there is a lot of slack in the chain from there. I don’t think the ones we saw had any codes.
Old January 17th, 2018, 10:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
Great one more thing to worry about
ac, lr4
Looking for 2011 or 2012 LR4 founD90 Wanted 0 November 3rd, 2017 05:47 PM
Texas Rovers 2010 SCARR Event April 15 - 18th 2010 chrisvonc Trips, Trails and Events 25 April 15th, 2010 12:06 AM
2010 eBrochures mpodgorski Misc. Chit-Chat 2 September 12th, 2009 08:14 PM
Vendor feedback - CA: Rover Accessories paulb Misc. Chit-Chat 7 February 24th, 2005 02:41 PM
Owner feedback for Raingler products wanted 007 The Vendors Loft 25 August 6th, 2004 03:35 PM
