LR3 Wheel Bearings (front) - Defender Source
Old March 6th, 2016, 03:13 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
At what mileage are people changing these at? Any reason not to go with the hub assembly from Timken (HA500601) at $158 per side shipped?
Old March 6th, 2016, 03:22 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
I went with that same one about 4 months ago at 138k. So far, so good.
Old March 13th, 2016, 01:09 AM
down_shift's Avatar
down_shift
Russell
Reading more it appears these Timken hubs are the genuine hub assemblies, but without the $150 Green oval box. I'm also seeing examples of wheel bearings letting go at low mileage (<80k) without warning. Mine have 76k. See attached. After changing the front diff fluid (35k - full and looked fine), checking for hub play (none), tire pressure (35f and 38r) and rotating the tires, the low frequency grinding persisted. One last comparison drive in my 4Runner with the same new AT/3s to rule out tire noise, just ordered a set hubs from Amazon. Looking forward to knocking back a few IPAs while swapping out the hubs Tuesday night after they arrive. What's quieter for the neighbors? Mighty blows with the BFH or air compressor cycling and brappp of the air hammer?
Old March 13th, 2016, 09:47 AM
Grover's Avatar
Grover
My ps front shell bearing went at 85k. In replaced both at the same time to be safe. I'm a belt and suspenders type of a guy...
Rear wheel bearings: "while I'm at it" list? MonLand Defender Technical Discussions 27 October 1st, 2013 07:34 PM
Rear axle noise at 15-20mph+ -> wheel bearings? MonLand Defender Technical Discussions 13 October 1st, 2013 01:10 PM
Wheel Bearings andy110 Defender Technical Discussions 3 November 10th, 2012 07:51 PM
Wheel Bearings and stub bearings Naplm00 Defender Technical Discussions 9 March 11th, 2011 10:17 PM
wheel bearings and seals Uncle Douglas Defender Technical Discussions 8 August 20th, 2010 08:18 PM
