Lr3 trans service - Defender Source
Old January 15th, 2015, 05:56 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Lr3 trans service
I hesitate calling this an upgrade but has anyone converted to the metal trans pan on your LR3? If so have you experienced any negative issues with the lower fluid capacity? Are you still satisfied with the modification?
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old January 15th, 2015, 06:10 PM
I've seen them leaking, but that's my only experience. What's wrong with the plastic pan? I guess it could be a problem off road, but a skid plate would be a better option in my opinion.
Old January 15th, 2015, 06:32 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
It looks like there are a couple metal ones out there. I've looked into it a little. Seems like it would make it alot easier to change the fluid/filter more regularly for those that need it. I'm curious to see what people have to say as well. The biggest pain looks like the refill procedure, which doesn't look that hard if you have a lift.
Old January 15th, 2015, 06:45 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Been running a metal ford pan with drain plug for the past year. No issues to report and holds nearly a litre more fluid.
I did a write up on the disco3 forum (I thinks it was) some time ago.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 15th, 2015, 06:47 PM
jpc1818's Avatar
jpc1818
james
1998 D1/06 LR3 HSE HD/16RRS Diesel
I went to the dealer, have 238k on my lr3. they said its lifetime and they would not touch it....
Old January 15th, 2015, 06:55 PM
lordhelemt's Avatar
lordhelemt
Paul
Nothing is wrong but 10yrs old and 100k miles so I want to replace the fluid and filter. Genuine appears to be a pita having to remove the exhaust and jacking the motor.
Will check the write up on the d3 forum
Thanks for everyone's feedback
Old January 15th, 2015, 07:50 PM
That's a lot of miles! Which dealer? I wouldn't hesitate to change it personally, but I guess I can understand why some people would be afraid to. I don't really buy into the whole not changing transmission fluid when it has high miles. If the clutch material in the fluid is holding your transmission together, its probably on its last leg anyway.
------ Follow up post added January 15th, 2015 07:52 PM ------
I haven't done one in a while, but I don't remember pulling the exhaust.
Old January 15th, 2015, 09:34 PM
Grover's Avatar
Grover
I changed my trans fluid and filter last summer. I was going to do the metal pan, but decided to go with the OEM ZF pan. The passenger side CAT pipe needs to be removed and the engine needs to be lifted about 2". Should be good for another 90k...
Also, I changed the electrical plug/sleeve while in there. The only way to change it is to drop the pan.
Here are some useful sites:
http://www.zf.com/na/content/media/u...28_Catalog.pdf
http://www.zftranspart.com/images/custom/mecha.pdf
http://www.disco3.co.uk/forum/topic9...ansmission+pan
Cheers...
Old January 16th, 2015, 09:49 PM
roverman2010
1985 LR 90 200Tdi
Found this while looking for else,
Ford A/T pan # 9L3Z-7A194-A which was $37, same as the Ford Raptor model
Ford filter 7L1Z-7A098-A $30
both online at sunrise ford
the A/T gasket FEL-PRO T0518753 (the first #5 could be a S) Amazon $30
ID:	111249   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old January 16th, 2015, 10:12 PM
jpc1818's Avatar
jpc1818
james
Huntington Land Rover. I spoke with several of the service people and two mechanics.
I know the miles are high thats why i want to change it. Once it warms up, i will likely tackle it myself.
Old January 17th, 2015, 10:41 AM
lordhelemt's Avatar
lordhelemt
Paul
Originally Posted by roverman2010 View Post
Found this while looking for else, Ford A/T pan # 9L3Z-7A194-A which was $37, same as the Ford Raptor model Ford filter 7L1Z-7A098-A $30 both online at sunrise ford the A/T gasket FEL-PRO T0518753 (the first #5 could be a S) Amazon $30
Awesome. Thanks!
Old January 17th, 2015, 10:52 AM
What interval do you recommend? My LR4 has about 55k now and think I should do it (when it gets warmer) as well. Have not researched how hard it is yet (if any different from an LR3)
Originally Posted by pendy
I'm here for the D's
Old May 17th, 2015, 08:54 PM
lordhelemt's Avatar
lordhelemt
Paul
I finally got around to this over the weekend and this is what I learned.
Everyone has their own reason for doing the conversion and for me it was to make future services easier and the benefit of only having to replace a $30 filter is a bonus. I bought the Ford pan, filter, felpro gasket, and B&M drain for ~$90. The electrical connector sleeve was $20 from the dealer. 7liters of fluid was $145 and hardware was $10-15 from the LHS.
My pan was held on with T-27 torx head screws. They have fairly large head for that small size bit so they were difficult to get off. Years of aluminum to steel contact created a good bit of corrosion. Before you start make sure you use a good straight bit and go after the difficult to reach screws first. You may want to tap on them first to help loosen them up. The one nice thing about these crappy screws are the heads are fully exposed so you can get vise grips on them if necessary. I need to use vise grips to remove ~1/2 of my pan screws.
Once you get all the screws off dip the corner of the pan into your drain pan and another couple of cups of fluid should spill out. You'll want to do that before cutting the pick up tube.
I used a small hacksaw between the pan and trans to cut the pick up tub. If you shine a light in the gap between the pan and the trans you should see if about 1/4 of the way back (motor side). It was a little awkward but eventually you'll saw thorough it.
Given the difficulty in removing the screws on the front and back of the trans pan I decided to replace all the screw with regular hex head M6x100x16mm bolts. I'll use antiseize on the threads and external tooth washers to hold them in place.
Reverse to reassemble, correct? Well, unfortunately not so. The Ford pan I bought has a reservoir in the bottom and that little bump is preventing me from sliding the pan in place. If I drop the exhaust pipe the pan should slip in but i'm doing this for easier future maintenance so I need to order a new pan that is flat bottomed. I think I've found one and I will post the part numbers once it is confirmed.
Here are some pics. Good luck to anyone that decides to do this mod.
ID:	121000   Click image for larger version
ID:	121002   Click image for larger version
ID:	121004   Click image for larger version
Old May 18th, 2015, 12:04 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
What oil did you go with?
Also for the filling part, did you worry about temperature?
How about flushing the transmission? Is that something you did?
For my father's LR3, I ordered a flat bottom pan kit from the UK (last year or maybe two years ago). Went with OEM oil and no flush (seemed iffy to do for the first time... Maybe if you have spare transmission cooler lines you can start from?).
As an FYI, the gearbox manufacturer came back on the "lifetime" for the transmission oil. I can't remember what interval they now use, but my LR3 has close to 90K and I plan on doing it around 100K.
My father reported better MPG after the oil change (he does a lot of towing with his truck).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old May 18th, 2015, 12:31 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Good info, Paul. Thanks for posting your experience.
On occasion, my LR3 has an abrupt kickdown during slow to medium acceleration transitioning out of a rolling stop following a medium to strong brake. Feels if it hesitates for a 1/4 second thinking do I remain in 2rd or 3rd during this acceleration, or kick down to 1st gear? It would be smooth if a softer acceleration (remain in 2rd or even possibly 3rd) or smooth if a harder acceleration as it would instantly kickdown to 1st. It is difficult to reproduce, but the end result is not smooth when kicking down to 1st. 62k on the ODO.
Is this normal?
Old May 18th, 2015, 05:45 PM
lordhelemt's Avatar
lordhelemt
Paul
Russ, I don't have your shifting issues. I'm doing this as preventative maintenance. With 105k miles on the clock I figured $250 was money well spent to get me another 100k miles.
Loic, i'm going with the proper ZF fluid. I wasn't adventurous to try the Ford fluid.
New pan should be here this week. I'll post pics and part #s if it all works out.
Old May 18th, 2015, 06:00 PM
The pan is held on with T40 torx bolts, not T27. You probably wouldn't have had any issues if you had been using the correct size.
Is this normal?
I think there is a software update for that.
Old May 18th, 2015, 07:57 PM
lordhelemt's Avatar
lordhelemt
Paul
[QUOTE=Jymmiejamz;638487]The pan is held on with T40 torx bolts, not T27. You probably wouldn't have had any issues if you had been using the correct size.
The T40 are the new bolts. I never messed with the pan before and these are the bolts that have been on there since new. The early models came with T27, it wasn't until later they started using T40s.
Old May 18th, 2015, 08:21 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
I have the same symptoms on my '06 LR3.
Also intermittent transmission fault limited gears available, engine system fault...
"On occasion, my LR3 has an abrupt kickdown during slow to medium acceleration transitioning out of a rolling stop following a medium to strong brake. Feels if it hesitates for a 1/4 second thinking do I remain in 2rd or 3rd during this acceleration, or kick down to 1st gear? It would be smooth if a softer acceleration (remain in 2rd or even possibly 3rd) or smooth if a harder acceleration as it would instantly kickdown to 1st. It is difficult to reproduce, but the end result is not smooth when kicking down to 1st. 62k on the ODO.
Is this normal?[/QUOTE]
Old May 18th, 2015, 09:09 PM
[QUOTE=lordhelemt;638540]
Really? I've only ever seen a T40 on the ZF trans in the RRS, LR3, and Range Rover. I've probably had about 50 or so of those pans off.
Reseting the service message on my LR3. Anyone ever try the hawkeye tool from BA? Neil McCauley Defender Technical Discussions 7 January 9th, 2012 03:06 PM
60K Service Cost and Checklist? boshea Defender Technical Discussions 12 February 26th, 2004 11:34 AM
On-line Service Manuals Ragland Defender Technical Discussions 11 February 13th, 2004 11:43 AM
Service Manual Advice cdnpaul Defender Technical Discussions 1 December 3rd, 2003 08:08 AM
would you buy a '97 d-90 with 60k & no service rcd tomken Defender Technical Discussions 8 November 17th, 2003 08:01 PM
» Defender Registry
D
drsmiley
110
emhewitt110
Add your Defender
