Lr3 trans service - Page 3 - Defender Source
Old May 23rd, 2015, 11:44 AM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
The kit from Alto was ~$82 all in. You'd just need to buy a separate drain valve if you want one ~$10.
Not sure what the replacement filter/gasket cost but I'd assume 1/2 price of the kit
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old June 8th, 2015, 11:51 PM
mx468
Dan
LR3 2006 v8 4.4
Drain bolt???
Originally Posted by lordhelemt View Post
I ordered the ALTO kit. It comes with the pan, filter, gasket, bolts for about $82 shipped. Part #183650. Easily fits without removing anything other than the old pan. It did NOT come with a drain plug so you'll want to make sure you order one of those before the install.
The image on the right is the new pan and it comes with magnets.
I have the same pan but haven't installed it yet. My pan didn't come with a drain bolt or drain hole either. Did you drill a hole and just installed a drain bolt. If yes, where did you purchase the drain bolt and how easy was it to drill, install drain bolt/location, etc. thanks.
Old June 9th, 2015, 07:12 AM
lordhelemt's Avatar
lordhelemt
Paul
I bought a B&M drain plug on ebay, it was ~$10. It was easy to install. You just need to drill a 1/2" hole and I match the location on the factory pan.
Old June 9th, 2015, 08:47 AM
mx468
Dan
LR3 2006 v8 4.4
Couldn't you just drill a hole tack weld a nut on the inside of pan, screw in a bolt using copper washer? The bolt would be flush against pan. The b&m bolt looks like it's sticking out.
Old June 9th, 2015, 04:38 PM
lordhelemt's Avatar
lordhelemt
Paul
I don't see why that wouldn't work.
Old June 9th, 2015, 07:16 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
The pan is just plain steel?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old January 14th, 2017, 08:40 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Do you have to remove the selector cable to get the bolt for the heat shield bracket out?
Old January 15th, 2017, 03:58 PM
lordhelemt's Avatar
lordhelemt
Paul
No you should be able to get it out with the cable in place but it was kind of a pain.
Old January 15th, 2017, 09:02 PM
Broncoduecer
peter
D90
On my LR3 I had to unlock the selector cable from the mount to get it to give enough room to get the last bolt from the heat shield bracket free. Just needed like a 1/4 inch and I got the bolt out.
I did have to cut off the bolt on the front driveshaft side. I used a ratcheting wrench and it backed out all the way into the driveshaft. So a little sawzall there and I was fine. But still note worthy. I'm not sure if you can get it out all the way with an open ended wrench. It's tight clearance around the cross members for the T40 3/8 drivers. You really need a 1\4 driver to get them all out.
Sleeve connector looks hard to get to but eventually manageable. I didn't get that far yet but next weekend.
Old January 15th, 2017, 10:09 PM
Grover's Avatar
Grover
How do you fill the transmission with fluid and how did you know you got the correct amount in there?
Old January 15th, 2017, 10:18 PM
Broncoduecer
peter
D90
There is a port on the side of the transmission to fill it. But basically after you drop the pan, reinstall the new one, you add 4ish quarts, start the engine. When the trans reaches 40 deg C you should top up the fluid and have a slight drip out of the fill hole. After the engine is running it should take 3ish quarts. Temperature is important for this, the fluid expansion with the right temp is important to tell when the fluid level in the trans is right.
Old October 2nd, 2017, 02:08 PM
A couple of notes as I just finished this up on my LR3 using the updated conversion kit to a metal pan:
- I replaced the Automatic Transmission Valve Body Sleeve (#TZV500010) at the same time, highly recommended as the orings dry out/shrink. Make sure you properly seat this all the way in before you push the slide lock back up in place...apparently the unit *will* lock in place about ~2mm before the actual proper lock position, so take a before-and-after photo to compare (thanks to Jymmiejamz for the heads up on this, so was not an issue for me)
- the replacement pan comes with smaller head M6 bolts, and the pan is metal so doesnt have the "sleeve" in each hole....as such, make SURE to use a lock washer (the tooth kind is recommended) and I'd probably suggest locktite as well. I didn't initially and after a day went back to inspect and found the bolts had actually loosened up!
- original torque spec on the factory bolts is ~12nm....not sure what/how that translates to the ford pan bolts, but I went slightly higher (~15nm) when I redid then with tooth washers & loctite. Will check & inspect.
- fill capacity is looking like somewhere in the 5-6 quarts following the cold fill followed by get trans up to ~110-120*F and finish filling while running.
- I removed the tcase bolt that fastens to the chassis and jacked up the entire assembly to get to the rear pan bolts, was much easier and gave more room to work.
- I also cheated and used our shop lift....was intially going to do it on the ground on my back, but glad I did not as I'm getting too old for that BS .
If I think of anything else pertinent I'll post up.
Old October 2nd, 2017, 04:06 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Excellent Notes! How much time would you estimate and where do you recommend sourcing the parts & fluids?
Old October 2nd, 2017, 05:26 PM
I was doing it on the lift and BS'ing with the guys/etc....so really didn't track the time per se. But was out of there by 3pm and got there around 10am or so. I'd say doing it on my back, no monkey business, probably about the same.
For the fluid, I went with the genuine ZF Lifeguard 6 fluid...but found out afterwards that the BG fluid *is* ZF compatible (and one of the recommended fluids for the ZF). Can't remember the BG # off the top of my head, but it's the one for the 6HP ZF (edit: pretty sure its the BG PN315).
For the connector sleeve, probably could be had at the dealership or similar - just make sure you go genuine.
Regarding the upgraded pan kits (metal pan, magnets, gasket, and new hardware) I know a guy who knows a guy that stocks the pan kits . Cough.
Old October 2nd, 2017, 06:31 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Sold. Put me down for the kit. Do I go to the dude's dude's website or is this 4th hand post suffice?
Old October 3rd, 2017, 12:28 PM
MonLand
Loic Fabro
Picture of the pan please? Would like to see what drain plug you ended up using.
Old October 3rd, 2017, 02:14 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Transmission Pan Drain Plug Kit - B&M Transmissions, Shifters, Torque Converters, Diff Covers, Coolers
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old October 3rd, 2017, 02:44 PM
Opted *not* to go with drain plug....wasn't sure it'd be a factor in application, *but* from chatting with Galpin there was always the possibility that adding a foreign object in the pan could affect the fluid dynamics of the flow in the pan.
That, and well introducing anything on a Rover that's another potential leak point - also a concern. So went sans drain plug, but can either just drop the pan next time or hook it up to the BG machine to flush it anyhow without removing the pan.
Old October 3rd, 2017, 02:48 PM
Naplm00
Matthew
Fluid dynamics accounted for in a built by the lowest bidder transmission? Doubt it
Old October 3rd, 2017, 02:51 PM
Galpin tends to over-analyze things, but then again he is building an electric Rover literally from scratch. Put enough of a "?" in my mind, but honestly was really more worried about introducing a leak point in the pan so that was the real nail in the coffin for me.
Reseting the service message on my LR3. Anyone ever try the hawkeye tool from BA? Neil McCauley Defender Technical Discussions 7 January 9th, 2012 03:06 PM
60K Service Cost and Checklist? boshea Defender Technical Discussions 12 February 26th, 2004 11:34 AM
On-line Service Manuals Ragland Defender Technical Discussions 11 February 13th, 2004 11:43 AM
Service Manual Advice cdnpaul Defender Technical Discussions 1 December 3rd, 2003 08:08 AM
would you buy a '97 d-90 with 60k & no service rcd tomken Defender Technical Discussions 8 November 17th, 2003 08:01 PM
