LR3 tire wear settlement - Defender Source
Old December 24th, 2013, 09:36 PM
Not sure if this has been posted, but if you've got an '05 or '06 that had it's tires or any tire replaced under 36,000 miles then you can participate. Amazingly, the crappy tires that mine came with (Goodyear if I recall) when purchased new DID wear out prior to 36K and I replaced them with Michelins...so hopefully I'll get paid, get paid:
http://www.lr3tirewearsettlement.com/
Old December 25th, 2013, 09:24 AM
36k miles? All newer Land Rovers wear out tires between 25-35k miles unless they are aligned, balanced, and rotated regularly. I saw one set of Goodyears last to 48k, but that vehicle (my uncles) got an alignment every other service and way only driven on the highway. I've replaced tires on the 2010+ RRS's with fewer than 20k miles.
Old December 25th, 2013, 09:43 AM
Actually, the Michelin Synchrones I replaced them with did 60k+ and just finally replaced them this summer. The only reason I even had to replace them was due to cracking on the sidewalls due to age, they still had 30%+ tread life. And I NEVER rotated them (literally), and just got one alignment a year.
I do however realize I am probably the exception to the rule. But I am obsessive about tire pressure and made sure I had no control arm bushing wear that could have compromised tire wear.
Needless to say I put another set of Michelins on, though the Synchrones got phased out and replaced by their Latitudes.
Old December 25th, 2013, 09:03 PM
That's impressive! Synchrones and Lattitudes are great tires, but the Diamaris is absolutely terrible.
lr3, tire
Curing mud tire uneven wear winn442 Defender Technical Discussions 2 April 11th, 2013 10:26 AM
WTB LR3 Rear tire carrier JPBrown Wanted 2 May 27th, 2012 09:01 AM
12.5" tire on a 7" rim? souza Defender Technical Discussions 16 August 19th, 2005 04:04 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
