Lr3 suspension - Page 2 - Defender Source
Old October 20th, 2014, 08:28 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Originally Posted by the rover shop View Post
I believe jimmy will correct me if I'm wrong but one of the reasons why the compressor was replaced with an updated unit was because of a faulty exhausting valve that would leak/stick open, dumping pressure reserves out, then when the system tries to level itself out by inflating itself it has no reserve so it lowers the highest ones to the lowest ones levels, if that makes sense.. Before you know it it's on its bump stops.. .....
This was all of a sudden, right after the trailer hitch popped off the ball. The rear tires were never off the ground. Before that everything was working fine. It occurred within seconds to minutes. All four corners on the bump stops.
MUDSUX
Old October 20th, 2014, 08:52 PM
jpc1818's Avatar
jpc1818
james
1998 D1/06 LR3 HSE HD/16RRS Diesel
If you need to rebuild the compressor i just installed a kit from http://www.bputah.com
rebuilding kit, dryer & new relay...
Not too difficult to do, and was ~250
Old October 20th, 2014, 09:56 PM
Forrest, give Justin at Lucky 8 a call and I bet he can help. This happened to his LR3 while wheeling it at the conclave. It was in the rocks at an incline and we had to get the truck level and then disconnected one of the sensors and fiddled with the position of the sensor until the truck was happy and raised up. But I know he had one of those diagnostic tools that let you mess with the settings and I don't know what all he was doing in the truck to make it go back up, but he did get it back up.
Originally Posted by pendy
I'm here for the D's
Old October 20th, 2014, 10:38 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Originally Posted by MUDSUX View Post
Gustavo did you ever get this fixed? My 2008 just started doing this yesterday. It's down to the bump stops and will not get back up again. The red suspension fault light is on and the "special programs off" light is on. Used the Faultmate but I cannot clear the faults:
U0421 Invalid data received from ride level control module
C1A01 LED circuit
C1A74 Rear left height sensor mechanism
C1A75 Rear right height sensor mechanism
I was pulling a trailer and when taking it off the hitch was stuck on the ball, I was in access height mode at the time. I used a floor jack to lift the trailer off the ball, raised it about 8-10 inches before it popped off. Right after that the faults started. I do have extended rods on but it has never given me a problem. Any ideas before I start throwing money at it? Thanks
I do not remember the exact procedure since it has been about 4 years since I dealt with suspension issues and 2 1/2 since I sold the LR3. I do remember that once you were at the bump stops you had to "initialize" the system before you clear the faults and it will work. I do not remember where but one of the menus allows you to manually run the compressor and manually control each valve. You can run the compressor then open each valve to raise it. There is also button in one of the menus that allows you to raise the vehicle or lower it, this may be a timed event I do not remember for certain. Once you have it back up to standard height you should be able to clear the faults. (This was with a faultmate msv2)
Do as you wish but I came to the conclusion that the shortened rods caused far more problems then they solved. I removed mine and went back to the stock length rods. I also wheeled mine more then most so running on pavement may be just fine.
Ryan
84 110SW County LHD
07 L322 Vogue
Old October 20th, 2014, 11:07 PM
Rugbier's Avatar
Rugbier
Gustavo
C1A01 LED circuit
Forrest,
Since you have J-Rods, I will suggest you put a floor jack under the Tow hitch and raise the car about 2 ", the with the car there disconnect the battery for few mins, re-connect and fire the engine with doors closed ( through window )
With the J rods if you go down, the sensors do not know where they are.
The compressor will not kick in as it is in safe mode , that should correct the issue
NO SIGNATURE
Old October 21st, 2014, 06:14 AM
Originally Posted by Rugbier View Post
Forrest,
This is very important. I didn't realise you had j-rods. When the vehicle is on the bump stops with j-rods the height sensors are out of range and will allow any movement of the suspension. Do this and you can probably clear the faults. Unless you have faults for your compressor, there is nothing wrong with it.
Old October 21st, 2014, 08:06 AM
the rover shop
shayne young
Hmmm, I seem to remember someone saying this wayyyy back in post 14.....
Old October 21st, 2014, 09:30 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
These are the only faults listed:
C1A01 LED circuit
Thanks guys. This is good stuff. I will try this tomorrow and report back. Still confused as to why it all of a sudden it dropped all 4 corners. I am worried there is a leak somewhere. Maybe when the hitch popped off the trailer the truck came down and the added pressure blew out something.
MUDSUX
Old October 22nd, 2014, 05:09 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
You guys rock! I jacked up the rear a few inches, started the car and all the faults cleared. I didn't bother disconnecting the battery at all. I guess the extended rods put the rear height sensors out of range and the car just didn't like it. everything is now working as it should. Thanks again.
MUDSUX
Old October 22nd, 2014, 05:37 PM
the rover shop
shayne young
That's what we are here for... Well that and all the skittles..
Old October 22nd, 2014, 11:57 PM
Skittles .....
And umm camping with cats that's why we're here 👳
95' D90 - daily driver..
LR3/LR4/RRS Air Suspension Compressor Blowout discojosh2000 For Sale - Parts 0 December 30th, 2011 09:51 AM
Suspension benh Defender Technical Discussions 30 February 17th, 2004 02:04 PM
Rear Suspension Question dnewman9 Defender Technical Discussions 3 February 1st, 2004 06:31 PM
Suspension! TwisteD90 For Sale - Parts 11 January 14th, 2004 04:13 PM
OME suspension, and tires huntahdefender Defender Technical Discussions 4 October 10th, 2003 04:14 PM
