LR3 Radiator Drain Plug - Defender Source
Old June 14th, 2016, 04:16 PM
Grover's Avatar
Grover
Question LR3 Radiator Drain Plug
Hmm...I was told the LR3 had two radiator suppliers, one having a drain plug and the other not.
Has anyone come across this? Here is a pic from my radiator...is this a drain plug? It's located on the passenger side lower corner in front of the alternator.
Cheers...
Old June 14th, 2016, 06:48 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I just fitted a Nisson rad and it had the drain plug
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old June 14th, 2016, 06:53 PM
Grover's Avatar
Grover
Nisson radiator???
Old June 14th, 2016, 07:48 PM
I would be afraid to remove that plug.
Old June 14th, 2016, 08:05 PM
Grover's Avatar
Grover
Why? Perhaps it may be brittle and crack?
Old June 15th, 2016, 07:59 AM
I'd be worried that it would break off or leak after removal. There are better ways to drain or flush the cooling system.
Old June 15th, 2016, 09:24 AM
Grover's Avatar
Grover
Ok, what method do you recommended?
Old June 15th, 2016, 09:28 AM
To drain I would just pull the lower hose. To flush, I would remove the small hose to the expansion tank and route it into a bucket. Run the engine and fill the reservoir as the water pump pushes the old coolant out of the upper hose.
drain, drain plug, lr3, radiator
Transfer Case Drain Plug Problem kzack Defender Technical Discussions 10 October 21st, 2010 08:14 AM
Wading plug and drain hole? T.U. Defender Technical Discussions 4 April 6th, 2010 03:48 PM
Drain Plug Diffs/Xfer Case Grover Defender Technical Discussions 7 November 11th, 2009 11:21 PM
where is drain plug for the swivel housing UpnOver Defender Technical Discussions 10 July 23rd, 2007 03:23 PM
Oil pan drain plug thread Pat Defender Technical Discussions 0 June 23rd, 2006 09:02 AM
