LR3 incognito brake controller? - Defender Source
Old April 19th, 2013, 12:05 AM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Anyone have any clever ideas for mounting a brake controller on an LR3?
I bought a can-am commander and with its supporting trailer is just a touch over the unbraked trailer recommendation. So I got the trailer with brakes. I already had the oem trailer light/brake harness installed. I bought a tekonsha p3 controller and adapter, but wanted to see what people have done to mount it.
I don't want to maul the cig tray, I prefer to do a standard mount or a clever mount somewhere in the drivers footwell. But I thought I'd ask what others have done to see if it inspires me.
Thanks for the info guys!
Pete
Old April 19th, 2013, 12:11 AM
Broncoduecer
peter
D90
Pic of the commander
Old April 19th, 2013, 12:22 AM
dlane's Avatar
dlane
David Lane
1997 AA Yellow #1147
I bought this... Nothing to mount. Just need a power plug...
http://www.amazon.com/Tekonsha-90250...ake+controller
Old April 19th, 2013, 12:58 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Could have bought a trailer with surge brakes...would have been much easier.
Just make sure you mount it where it it easy to manually activate if you get sway...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old April 19th, 2013, 01:13 AM
Broncoduecer
peter
D90
No worries man. Good point.
It was a custom build by echo trailers in UT. I Don't know for sure, but I think it's just regular old trailer brakes...I pick the trailer up next week. I requested "trailer" brakes, so I assume they are just standard electric brakes . The dealer asked me the, uhh are you sure you want trailer brakes question and I said yep. Like you said its pretty light.... He didn't think I needed it either, but I thought why not. I have some future plans that will require real braking so I thought so get ready for it.
Pete
Old April 19th, 2013, 01:15 AM
DMSLongLake
Dave Sherwood
1994 D90 ST
Pete
Just ask if they are surge or electric....if they are surge...no controller required.
Towed my 24ft boat on a dual axel trailer with surge and my old Range Rover on a car trailer with surge...never had issues...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old April 19th, 2013, 10:17 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
This really is my #1 beef with the LR3 in general, the dash is so busy that there really is no place to put anything. If you didn't need to get to the manual control I would say pull the center console and install it underneath there, I have stuffed lots of electronics there in the past.
Another possible location is the cover that snaps on to the front of the driver's seat, it's removable to get to the nav computer, and you could run the wiring either down the door trim or under the center console. Mostly out of the way, and you could still reach down and hit the switch if you needed to.
Old April 19th, 2013, 10:21 AM
My UK experience was all with surge brakes. Only discovered electric brakes in the US but provision for electric brake controller should have been made.
Old April 19th, 2013, 10:38 AM
Rugbier's Avatar
Rugbier
Gustavo
I have mine in the lower cowl above the pedals, I can reach it in case of need ( manual operation of the trailer brakes )
The D3 comes with a plug ( right cowl on tunnel ) where you plug a Ford connector ( for the P3 at least )
Could take pics tonight if needed
NO SIGNATURE
Old April 19th, 2013, 01:32 PM
navydevildoc
Neill Thornton
Yeah should have added that... The plug is there waiting to be used, it makes it a plug and play install.
Old April 20th, 2013, 03:34 PM
Broncoduecer
peter
D90
So they are full on real trailer brakes. Pulled pretty good on the way home. Interested to see how it does with the Utv on there. Used a lot more gas on the way back compared to going to get it. That gate is kind of like a sail lol.
Thanks for the suggestions fellas. I will dig around and see what makes sense and post the installed controller.
Old April 20th, 2013, 03:53 PM
Rugbier's Avatar
Rugbier
Gustavo
I tow / used to tow:
Snowmobile trailer with 4 sleds inside ( Enclosed ) total weight 6k
Rhino + King Quad + Honda Rubi on aluminum Trailer - total weight 4.2K
D-90 - Total weight 6.6k
Motorcycles - Road / Dirt - total weight 2.8k
Sankey - maybe 1.5k, my sankey has Disc Brakes, so I forgot was behind me all the time
All completely uneventful and in one of more occasion @ 80mph, NOW @ that speed with the UTV/Quads, I was getting 10-11mph unless I was on a very flat road then 13-14
You notice the heavy weight uphill of course and in highspeed exit ramps , otherwise, only if you look in the mirror
NO SIGNATURE
Old April 20th, 2013, 07:51 PM
Broncoduecer
peter
D90
Gustavo,
That's cool man, thanks for the info! Good hear hear it pulls lots of stuff!
It's a bit more labored, but not dogging when pulling this getup. More shifting of gears, but I think I will use that command shift more. Being at 5500ft+ all the time the hills do drop ya down pretty quick. I have yet to get below 3500ft, I bet the LR3 at sea level is pretty sweet.
Pete
Old April 20th, 2013, 08:59 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Hows that Commander treating you? Was the X worth the upgrade over the XT?
Anxious to see how the LR3 pulls the 90 in the heat for 1200 miles this summer...
Old April 20th, 2013, 09:16 PM
mightymg's Avatar
mightymg
Lane Farka
97 D90, 05 LR3, 95 RRC LWB
I towed my 90 to Moab with my lr3 a few times and it was great!! I used to just throw the brake controller in the cup holder, then when it wasn't in use I threw it in the drivers door pocket. Just a thought.
project whore!
95 RRC LWB-- DD
97 D90 37 " krawlers, coilovers, beadlocks, stretched
05 LR3 - Mamas/ tow rig
- Moab rally vids 2010
Old April 21st, 2013, 02:21 PM
Broncoduecer
peter
D90
I think the fox shocks really make a difference. And as the dealer pointed out you can add the winch for less than you can buy the shocks for. The dealer has a little dirt lot next to his place and we got to test just about every model and even some cats. In the end I liked the x the best. i think the fox shocks help with the big hits. I've put abut 100 miles on it so far and really like it it's crazy how much faster you go on the dirt compared to a defender or jeep. Bird hunting this year will be pretty cool.
1200 miles whoa ! That's a good haul.
------ Follow up post added April 21st, 2013 11:22 AM ------
Nice!
Your garage is awesome by the way. I should swing by with some beers next time I'm down your way.
Old May 5th, 2013, 03:52 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Thanks Peter! Jealous when you talk about ATVing, birding, etc! Cant wait to move back west.
brake, lr3
Tekonsha Prodigy brake controller Abrooks The Flea Market 14 March 9th, 2012 02:17 PM
Recommended Location for Brake Controller on D-110 NomaD110 Defender Technical Discussions 4 February 7th, 2012 01:15 AM
Advice on fitting a US-seven pin and electric brake controller onto a '83 110? turbodave Defender Technical Discussions 4 June 25th, 2009 02:48 PM
