LR3 drivability issue - Defender Source
Old March 23rd, 2014, 12:13 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I wanted to throw this out there to get some out of the box thinking; this one has stumped me and I think I maybe holding on to tight:
06 LR3 V8 with about 80k miles. Chronic P0171 and P0174 faults, low fuel economy.
Tried the easy obvious stuff like PCV valve, software update, and MAFS with no gains.
Also ran a course of BG products through the tank and intake.
Replaced intake gaskets and o-rings, upper and lower, sent the injectors out for an ultra sonic cleaning and "dyno" testing before and after ( never received the dyno report and overall wasn't impressed with that service).
Short term mix can move upwards of +30.
O2 sensor activity also within range.
Intake hose intact.
Performed a smoke test and didn't have any issues.
No EGR faults.
Spark plug gaps barely worn, but are the original plugs
Customer also states that stalling symptoms most often occur below an 1/8th tank. Haven't had the fuel pressure gauge on during that event, but normally the pressure readings are within spec, and the P-codes will come on at anytime, full or not.
Engine runs strong, smoothly; only was able to get 13mpg avg over the last 800 mile run. Not far off what my own 06 LR3 does (14.4 over 750 miles recently) but the owner is convinced it has been better.
Accepting any ideas!
Trevor
Email is
Same place, new dogs.
Old March 23rd, 2014, 12:39 PM
Can you swap ECM between the two vehicles without creating problems elsewhere?
If the fault codes follow the ECM that would suggest its faulty.
Old March 23rd, 2014, 01:39 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
I would do the plugs, wires, fuel filter (if LR started using them again) and a fuel pump, at 80k miles i wouldnt be surprised if you needed a fuel pump, and spark plugs are generally a 30-50k mile part, but im sure you know all of this...
Old March 23rd, 2014, 02:10 PM
P0171/4 are a constant problem for us at the dealership. So many different things can cause this, and no one thing will fix it. I would start with a mass air flow meter because its the cheapest thing, and it has fixed a few for us, but it won't throw MAFS specific faults. Another thing that can cause issues is the oil filler cap. If you can swap those from another car, that is the best thing to do to verify it by looking at the long term fuel trim.
Old March 23rd, 2014, 02:14 PM
If it was a jag, it would be the throttle position sensor on the throttle body.
Old March 23rd, 2014, 05:04 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
You most certainly can NOT swap ECUs between trucks unless you have a way of completely re-programming the unit. Not only are the CCFs different, but the VIN is baked in to many parts of the 30 some odd ECUs on the LR3. If they don't agree, nothing happens when you turn the key.
Old March 23rd, 2014, 06:44 PM
I had my doubts which is why I threw the caveat in
Old March 23rd, 2014, 08:25 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
+1 for the TPS...was the cause for mine....had some sort of carbon buildup or something...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old March 23rd, 2014, 08:33 PM
Where is the TPS on an LR3?
Old March 23rd, 2014, 08:53 PM
In my experience a dirty throttle body will set a P0101 Mass air flow sensor fault. I have been told by Land Rover tech line that it is not possible for a mass air flow sensor to cause this fault. I can't recall ever replacing a throttle body in an LR3, but I've cleaned hundreds of them.
The throttle position sensor would be integral to the throttle body since it is drive by wire and not a throttle cobble.
Old March 23rd, 2014, 10:06 PM
navydevildoc
Neill Thornton
It's on the pedal down by your feet. The LR3 is drive by wire.
Old March 23rd, 2014, 10:21 PM
That would be the accelerator pedal position sensor, not the throttle position sensor. The throttle position sensor tells the PCM the position of the throttle plate. It is integral to the throttle body and not serviceable separately.
Old March 23rd, 2014, 10:30 PM
navydevildoc
Neill Thornton
Ahhh... yeah you are right....
Old March 24th, 2014, 09:37 AM
Roverlab
Trevor Griffiths
I am most intrigued by Jimmy calling it a "throttle cobble".
Ok, a cap is easy enough.
I've been trying to focus my diagnosis on things that would be common to both sides of the engine as both faults are the same for each side of the engine and long term/ short term values are nearly identical. So, a large vacuum leak or air flow monitoring such as PCV, filler cap, intake hose, EGR, MAFS make logical sense. Unfortunately, other than replacing the EGR- which I would think would set a fault if the pintle were carbon-ed up and sticking open and replacing the oil filler cap, the other items haven't had an effect.
About to fit the cap from my perfectly awesome running LR3 and go for a drive- have run out of coffee, so why not.
Thanks for all the responses and I'll update later today.
Email is
Old March 24th, 2014, 05:54 PM
Roverlab
Trevor Griffiths
I see by another thread that I may have inadvertently nudged the bee-hive. I was only looking for some outside opinions on this particular issue and didn't mean to stir up an anti-LR3 thread/section sentiment.
I understand this is the Defender sand box and I'll happily take my shovel elsewhere.
FWIW I think I'm onto the solution for this LR3; somebody let me know if it's ok to post the results, and then I'll be gone.
Email is
Old March 24th, 2014, 06:04 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
I'd be very interesting in hearing the results. It is post like yours that keeps us coming back. Thank you.
Old March 24th, 2014, 06:59 PM
Grover's Avatar
Grover
Thumbs up
Keep us posted. Several of us, diehard Defender owners, own D3's...
Cheers...
Old March 24th, 2014, 07:03 PM
The Dro
Dro
1988 Ninety
We all blame Russell for that cluster #&@$€
Please let us know about your findings.
Old March 24th, 2014, 07:10 PM
There is an LR3 thread every week...
Please share the fix, or at least PM me with what fixed it. As I said before, we have these codes constantly, and there isn't a definitive fix.
Old March 27th, 2014, 06:59 PM
Roverlab
Trevor Griffiths
Fuel pump. On a test drive with a pressure gauge on the windscreen, I saw erratic readings, with pressure lowering under load, some times dipping into the 20's.
Replaced the pump and regulator- comes as one piece- and found that the access panel in the tank requires it's own special clamp and seal. The clamp looks like a typical hose clamp but has 2 collapsible segments and a shear bolt on the clamp drive so that it can't be overtightened.
P/N LR006778, around $50.
The pump is considerably more!
Now have long term fuel trim below 1% at 70 mph cruise and most noticeable to the customer will be fuel economy numbers back into the upper teens instead of single digits. Going to fill the tank and drive some more, but it's nice to resolve this one after months of ineffective tries.
Thanks all for the ideas and support!
Email is
lr3
Fuel Pump Issue bjenk Defender Technical Discussions 12 December 5th, 2004 09:00 PM
Article from the September 2004 Issue of LRE norros Misc. Chit-Chat 8 September 16th, 2004 02:13 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
overheating issue--viscous fan Davis Defender Technical Discussions 5 August 4th, 2004 12:11 PM
Private Messaging "Read Reciept" issue? chrisvonc Support & Suggestions 0 May 23rd, 2004 08:51 AM
