LR3 Coil Pack wiring harness/plug - Defender Source
Old November 24th, 2014, 07:06 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Changed the spark plugs on the wife's LR3 and in the process the red/white wire pulled from the connection that goes to the coil pack. Is it repairable or do I need a new harness/plug?
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old November 24th, 2014, 07:20 PM
Can you post a picture of the plug?
Old November 24th, 2014, 07:42 PM
lordhelemt's Avatar
lordhelemt
Paul
Sorry I thought i did. Here you go. It looks like a crimp connection, i've removed the little blue boot but haven't been able to remove the little metal connector.
Old November 24th, 2014, 07:45 PM
It will likely require special tools to remove the pins. I have an LR4 engine harness at work, I'll have a look tomorrow and see if any of the connectors are the same. Can you take a pic of the front of the connector as well?
Old November 24th, 2014, 07:53 PM
lordhelemt's Avatar
lordhelemt
Paul
Here is a pic of the front. Any idea what tool is needed to remove the pins?
Old November 24th, 2014, 08:26 PM
Paul, you just need to figure out what kind of connecter that is (weather pack, etc) and then finding the tool is easy. One of these multi-tools might do it
http://www.tooltopia.com/lisle-14900.aspx
And once you know what kind of connector, a replacement pin should be easy to get if you need it as well.
Originally Posted by pendy
I'm here for the D's
Old November 24th, 2014, 10:13 PM
lordhelemt's Avatar
lordhelemt
Paul
Looks like a sumitomo connector and there are GM/Toyota part #s as well. Going to see if I can source a pigtail to solder in at the dealer and get the car back on the road. I'll post part #s if successful.
Old November 24th, 2014, 10:14 PM
There are probably 20 or so Land Rover connector tools in the Special Tools cabinets, and a lot of times the connectors won't even come apart. It will likely be easier to just splice in a new connector.
Old November 25th, 2014, 08:05 PM
lordhelemt's Avatar
lordhelemt
Paul
Thanks to all that replied. I was able to source a used plug with wires locally and it works fine.
this plug doesn't appear to be available though LR but I found a Toyota part # 90980-11885 but it appears it is only for the plug with no leads. GM part # 88974044 appears to have leads (not confirmed) so should be a good replacement/repair for a damaged coil connector. Both are special order items from the dealer so I cannot confirm these would work but wanted to put this out there for anyone that may be attempting this repair in the future.
ac, coil, lr3, wiring
D2 Trailer wiring harness or plug OE Capt Milks Wanted 0 September 23rd, 2011 09:00 AM
Coil Pack D90DRC Defender Technical Discussions 0 October 10th, 2009 04:25 PM
OBDII coil pack RoverC For Sale - Parts 3 May 23rd, 2009 07:24 PM
OBDII Coil pack RoverC For Sale - Parts 3 June 24th, 2008 08:30 PM
Coil Pack tron Wanted 0 November 21st, 2005 05:03 PM
