LR3 Clutch Actuator fail? - Defender Source
Old May 31st, 2016, 09:05 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Coincidence???
It’s starting to get hot here and the wife noticed the passenger side a/c was blowing a touch warmer than the driver side vents. I read if you press the recirc and econ buttons while turning the ignition on the car would calibrate the flapper, so I gave it a try. Seemed benign so I didn’t really pay much attention and nothing stood out. I switched the ignition off then back on and it triggered a bunch of unrelated faults.
The most concerning fault is the “low mountain” is flashing green (as well as “high” and “low” on the tcase selector) as if it is trying to switch into low gear. It’s also throwing a HDC and parking brake fault.
Lynx is showing the following faults but I’m not able to get them to clear.
P-186D Clutch Actuator Stuck
U-0148 Invalid Data Received from Vehicle Dynamic Control Module – unexpected operation
U-0403 Invalid Data Received from Transfer Case Control Module - unexpected operation
U-0421 Invalid Data Received from Ride Level Control Module – unexpected operation
Did pressing the recirc/econ buttons trigger this event or it is just a coincidence? No issues before attempting to calibrate the right/left sides so I find it strange that all of a sudden it’s throwing these faults. It’s a 2005 HSE with rear elocker.
I made a half ass effort to mess/wiggle the wiring on the actuator. Has anyone replaced one of these actuators? Do they really go bad and is it as much as a pita as it looks from beneath the truck? Should I drive the truck around the block to see if the fault clears, or at least to see if it make the transition from high to low gear?
Any help or guidance would be appreciated!
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old June 10th, 2016, 10:05 PM
lordhelemt's Avatar
lordhelemt
Paul
I just wanted to close the loop on this thread and hopefully save someone some time and $ if you find yourself needing to replace the rear diff motor.
The problem with this repair is getting to the 2 rear bolts. The tech manual doesn't give any guidance and the only thing I could find online mentioned donating a lot of skin to get to those back 2 bolts.
To get to the back bolts
1) drop the spare
2) remove the evap canister
3) remove the metal shield on the tcase module
From there you can easily get the back 2 bolts on the diff motor. You may need to rotate the gear to get the motor and diff to line up but other than that its a pretty straight forward repair.
You may want to presoak the bolts, I found them kind of rusty, and while you're back there lube the spare tire cable. I didn't realize how hard mine was to turn until it was lubed up.
ID:	151512   Click image for larger version
ID:	151514   Click image for larger version
Old June 12th, 2016, 06:30 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
So this was a total coincidence? Damn.
ac, clutch, lr3
D1 Misc parts: Rear upper shock mount, Door Actuator AWR3382 w/ Mounting Plate jamesepoop For Sale - Parts 0 March 24th, 2015 08:48 PM
Changing vacuum advance actuator on NAS v8 leastonce Defender Technical Discussions 3 September 7th, 2014 10:14 PM
LR3/4 emergency brake actuator question cgalpin Misc. Chit-Chat 14 September 27th, 2013 05:07 PM
Window Motor and lock actuator tomaco1 For Sale - Parts 2 April 26th, 2011 09:57 AM
Off-topic, Need DiscoII door lock actuator... RedRhinoProducts Wanted 0 January 19th, 2005 05:57 PM
