LR3 blend motor noise - Defender Source
Old March 7th, 2016, 07:32 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Anyone notice the blend motor noise when turning on AC or heat? Mine sounds like it's coming from passenger side floor. Everything works as should, just sounds like a windshield wiper on a dry window for about 1 second.
Will this fail before any action is needed?
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old March 7th, 2016, 07:57 PM
Grover's Avatar
Grover
I'd like to know too. Mine has been doing this for three years.
Old March 7th, 2016, 08:05 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Also have it. But I was told it's just because the LR3 likes me so much it's taken up my enthusiasm for farting.
Old March 7th, 2016, 08:44 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Ah, the Rude Noise Generator. If your creative, you can release the glove box limit straps, put a little lube on your finger tip and snake your arm/hand up to the linkage. The noise comes from a linkage follower along a guide.
Email is
Same place, new dogs.
Old March 7th, 2016, 08:48 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Mine did that. Dealership removed the steering wheel & dash top, lubed whatever it was, noise went away.
Good luck!
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old March 7th, 2016, 08:56 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Just informed by a LR tech that it's an hour labor to lube part by dealer and there is a Technical Service Bulletin.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old March 7th, 2016, 08:59 PM
Basically you need to remove the right side vent and the upper glove box insert. You have to really yank the shit out of it to get it to come loose. Then look back in the dash and you should see a little white lever. It will be more noticeable if you cycle the recirc so you can see the door move. Then take some grease, doesn't matter what kind, and smear it all over the lever. It will take 20-30 cycles before it actually becomes quiet.
------ Follow up post added March 7th, 2016 09:02 PM ------
FWIW, the warranty time is .20 hours, so you might be able to get it done for even less.
Old March 7th, 2016, 09:35 PM
jafir's Avatar
jafir
Jafir Elkurd
I did this to my previous lr3. I had best luck when I ignored the exact details of the TSB. I think it said to turn the hvac off after selecting recirc or fresh or whatever. It's wrong. At least on mine when I selected off it moved to where I couldn't grease it as well. So I tried it in multiple positions until I could grease it enough to be quiet.
LR3 - Annoying 'dash' noise down_shift Misc. Chit-Chat 2 November 16th, 2015 11:16 AM
LR3 Rock Crawl Mode noise RRCbass Misc. Chit-Chat 7 October 24th, 2015 08:38 AM
LR3 / RRS blower motor heater/AC #JGC500050G nathanwind For Sale - Parts 1 July 19th, 2012 10:59 PM
wind noise with fiberglass top GliderKing Defender Technical Discussions 4 October 10th, 2003 04:13 PM
