LR3 - bad ball joint - Defender Source
Old July 11th, 2017, 11:54 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
New control arms 30k miles ago. The ball joint nut is tight. The nut and threaded shaft is moving with the wheel bearing carrier. Looks if the ball joint is bad. Anyone see something else? Aftermarket control arms from AB. Guess I should have stuck with genuine. https://youtu.be/oqLG7titOpA
Old July 11th, 2017, 12:00 PM
down_shift's Avatar
down_shift
Russell
If I'm going cheap, how is Dorman? Even more of a POS?
Old July 11th, 2017, 12:19 PM
Naplm00
Matthew
Dorman is meh but there are other options on rockauto for less. You can also just press out the ball joint they are about $20
Old July 11th, 2017, 06:26 PM
down_shift's Avatar
down_shift
Russell
Has anyone pressed out a ball joint while the control arm remains installed? Wondering if this kit has the right size adapters:
https://www.amazon.com/ABN-Joint-Ser.../dp/B01BUI5VCW
Old July 11th, 2017, 06:38 PM
Naplm00
Matthew
I haven't done it on a lr3 but on a f150 it common practice. Loosen the other mount bolt and pullit Down. Hf has a kit that is cheaper than that and a
Easier to return
Old July 11th, 2017, 07:53 PM
WK2Burner's Avatar
WK2Burner
Francis
1991 D90 200TDI
I agree. They are about 10 minutes from where I live and I used to sell all of their stuff. Some good, some OK. Mainly stuff like odd bolts and window cranks back in the day. Good family though and nice people.
Either way, my LR3 in 90K miles I did about 5 sets of control arm bushing which included 2 sets of control arms. If I still had it I'd be running poly bushings and OE ball joints. Never actually had a ball joint go bad. That all said you can do the ball joints, but my bet those bushing go south anyway so might be worth just getting new arms. My .02 but I felt that pain a few years back. Good luck.
Old July 12th, 2017, 07:21 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Russ, might give Walid a call. I know his shop is pretty slow in the summer so he might be willing to bargain. Never hurts to ask.
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
Rear Ball Joint Buckon37s Wanted 4 April 9th, 2006 06:54 PM
CV joint gone bad? Hans Defender Technical Discussions 5 December 4th, 2005 04:24 PM
rear ball joint mattdh Defender Technical Discussions 3 October 13th, 2003 04:28 PM
