LR3 Antifreeze - Defender Source
Old November 22nd, 2014, 06:02 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
LR3 Antifreeze
Started a small job on the wife's LR3 but since I was already "in there" decided to replace all the rubber under the hood. I drained most of the coolant for the hose replacement but only had ~3/4 gallon of the concentrated Peak Global Lifetime in the garage. I'm guessing i'm still about 1/2 gallon short but cannot find the Peak Global anywhere. Has anyone used the Peak Long Life in their modern Rover? In trying to find a substitute I read some anti-corrosives can eat though the plastic bits in the cooling system so I want to make sure whatever I use is the right stuff.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old November 22nd, 2014, 06:13 PM
lordhelemt's Avatar
lordhelemt
Paul
Duh...my Walgreens apparently has it in stock. I don't know why I didn't check there first.
Old November 22nd, 2014, 06:29 PM
All you need is Dex-cool. Might be too late, but the only hose you need to bother replacing is the bleeder hose T junction. The plastic splits in half and then you're stranded. Also, make sure your fully bleed the cooling system! The only other cooling system item I would recommend replacing is the thermostat housing including the piece under the throttle body. They crack and leak.
Old November 30th, 2014, 01:27 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
So, I replaced the bleeder t with the brass upgrade and swapped the entire thermostat housing assembly.
Now I can't seem to get the system to bleed. Tried 3 different "methods" from my internet searching and still have air.
Any ideas?
Old November 30th, 2014, 01:34 PM
Try disconnecting the small top hose from the radiator and fill the expansion tank all the way to the top until it comes out of the radiator. After that you can try running it with the expansion tank completely filled while opening the bleeder on the expansion tank.
Old November 30th, 2014, 02:32 PM
Any ideas?
Where did you source the brass-T from? I know I had it bookmarked to do this upgrade, but can't seem to put my fingers on it now.
------ Follow up post added November 30th, 2014 02:40 PM ------
Nevermind, answered my own question (and ordered):
http://www.jewellamberoil.com/sales/...njf2gj146d1fo5
Old November 30th, 2014, 02:41 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
Falconworks
http://www.jewellamberoil.com/sales/...roducts_id=278
While that brass T is nice, there is really no need for the T. A standard double ended hose barb would be just fine. I've never actually used that as a bleeder.
Old November 30th, 2014, 05:53 PM
lordhelemt's Avatar
lordhelemt
Paul
So, I replaced the bleeder t with the brass upgrade and swapped the entire thermostat housing assembly. Now I can't seem to get the system to bleed. Tried 3 different "methods" from my internet searching and still have air. Any ideas?
Just keep at it. Bring the car up to temp let it cool, open bleeder valve on expansion tank, top off, and repeat. It takes a while to bleed the system but eventually you'll get it done
lr3
Land Rover's New LR3 Marketing Campaign... OCD90 Misc. Chit-Chat 24 February 19th, 2008 10:27 PM
Disposing of antifreeze chris snell Defender Technical Discussions 11 August 8th, 2007 12:50 PM
Smells like antifreeze........... jchan88 Defender Technical Discussions 28 April 23rd, 2005 01:34 PM
Lr3 mhansen Misc. Chit-Chat 24 April 26th, 2004 11:00 AM
LR3 Unveiling...in NYC dmarchand Trips, Trails and Events 3 March 29th, 2004 01:44 PM
