LR3/4 emergency brake actuator question - Defender Source
Old September 26th, 2013, 03:26 PM
Does anyone know if the signal to these is simple - like 12v+ to engage or something?
Originally Posted by pendy
I'm here for the D's
Old September 26th, 2013, 03:43 PM
What's the issue with yours?
Old September 26th, 2013, 04:11 PM
Mine is fine. I am considering using one of these for the EV project but they are kind of pricey. Don't want to buy one unless I have a reasonable expectation I can control it easily enough.
Old September 26th, 2013, 04:27 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Charles, Wally might be able to help you with tht question. I 've seen him up to his knees in LR3 wiring before.
Old September 26th, 2013, 04:32 PM
They're junk, I wouldn't want one. You'd be better off getting some newer style calipers that have the emergency brake built in. Its actuated by CAN bus, but its probably powered by a 12V motor. There is a circuit board inside of them.
Old September 26th, 2013, 04:46 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Well..... Thanks for asking.... I just invested close to one hour on this for the future!
The short is: I don't know!
Here is what I know:
- The emergency brake module is expensive (i.e. $400 or more).
- it acts on the rear wheels (I thought this was on the transmission, so I learnt something! )
- It has a 32 pin connector to the rest of the car that includes the connection to the CAN bus....
- connector is wired to get input from the switch, clutch pedal sensor (which would not be used with an auto?), a bunch of battery and ground connections and plenty of "not used" pins.
So.... The only way to tell at this point (unless someone with more knowledge shows up) would be to call the manufacturer or to test the operation of the module while disconnected from the CAN bus.
I would make the assumption that being a safety item, it must be able to operate when the other components in the car are dead. But... That's just me thinking out loud!
Good luck!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 26th, 2013, 04:58 PM
Yes I was surprised to see it goes to the back wheels but I think Jason or someone already told me that once.
Sounds like it's managed via CAN bus. Not really a problem since I already talk CAN, but would need to sniff the packets and reverse engineer the messages. It makes sense that it's CAN since everything else is, and they have fancy logic like realizing when numbnuts is pushing the accelerator with it on and releasing it, and the smarts are probably in the ECU not the actuator.
I would use it to actuate the standard defender drum brake on the LT230 output. Jimmy, what part is junk? The actuator or the braking mechanism?
Except for the fact that I need a hand brake, it would be a nice "once it's on the road" project.
Old September 26th, 2013, 09:51 PM
There has to be a better option than this. The actuator is pretty prone to failure. I would guess that I've replaced at least 20 of them. The drum brakes that are mounted behind the disc brake rotor are junk too, but they are pretty cheap and easy to replace. If you are using this on an LT230 drum brake, I don't know what you would do with the second cable coming out of the actuator. The actuator works by tightening two cables that go to the parking brake drums located inside of the rear brake rotors. If they aren't adjusted properly, or one of the shoes has fallen apart (happens very often), the parking brake actuator will make a loud screeching noise and possible lock up, which could leave you stranded.
Old September 27th, 2013, 02:02 AM
God why! Sounds like a terrible idea when the normal lever is so easy.
Old September 27th, 2013, 08:25 AM
Jimmy, I suppose you could tie one side to the frame and it would anchor the other. I dunno.
Ron, I am just looking at my options. My motor is in the tunnel which makes it considerably wider and so I can't use the stock location for the lever (and I already gave it to Bill). I don't think I'd like it on the passenger side and above the tunnel is too nice a spot for cup holders or a console of some sort. I think maybe a foot operated one like on older american cars might be a solution as well.
Old September 27th, 2013, 08:26 AM
MonLand
Loic Fabro
After the iEverything why not the eEverything?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 27th, 2013, 10:08 AM
Makes sense.
Old September 27th, 2013, 11:08 AM
I just don't see that working, they are too sensitive to having the correct load. I would look in to using some rear calipers that have the parking brake actuators built in, such as on a Range Rover Evoque.
Old September 27th, 2013, 11:11 AM
Mmh, but I don't suppose they fit on a defender/rrc axle though do they?
Old September 27th, 2013, 05:07 PM
I highly doubt that. I imagine lots of new cars use this form of parking brake. I bet you can find something. I'm sure anything modern will be signaled via CAN bus.
ac, brake, lr3
emergency brake cable path and mount? lrna04 Defender Technical Discussions 5 July 13th, 2012 10:56 PM
Emergency Brake Part founD90 Wanted 3 September 15th, 2010 10:14 PM
Emergency Brake Cable Hardware CDeWan Wanted 0 February 5th, 2010 01:52 AM
Emergency Brake Issues Ragland Defender Technical Discussions 10 April 7th, 2005 07:09 PM
