LR3 - 05, 06, 07, etc - Page 3 - Defender Source
Old November 17th, 2013, 10:07 PM
They extended the catalyst warranty on on 03-05 Range Rovers because of the welds on the convertors cracking. An LR3 should have an 8 yr 80k warranty on the emissions system.
Old November 17th, 2013, 10:09 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
There's your answer
Old November 17th, 2013, 11:13 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Is there any documentation out there on this?
It's in your owner's manual. I forget which book, but I believe it is right in the front of one of them.
Old November 17th, 2013, 11:32 PM
Damn that's what I thought...longer would've been nice!
Old November 18th, 2013, 05:15 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
More digging...looks like it could be the timing chain tensioners (4 total), guides, or the VVT units (2 total). Very labor intensive job...10 hours by the book, so it would actually be more cost effective to change out all those parts once the front is off instead of finding out its the other side or the VVT and not a tensioner or the wrong tensioner. $1400 in parts alone.
Loud rattle on cold start, faint ticking at idle. Pretty sure it is not the cats. Common enough to have threads on LR/Jag forums...
Good lord.
Old November 18th, 2013, 09:26 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
What engine(s) seem to be affected based on your research? [hint: please don't say V6]
MonLand
1995 D90 NAS
1996 Discovery NAS
Old November 18th, 2013, 09:33 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Jag 4.4 V8
Ford V6 seems to be problem free!....
Old November 18th, 2013, 11:51 AM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
My wife has the 08 RRS (4.4L). Pretty much the same truck.
In addition to what the others have said, LR had a problem with a coating they used in the diffs or axle housings. Basically it would chip off into the oil after a while and wipe the diffs. I cannot remember where, but I found a letter from LR that had what VIN's they shifted over to a new coating that does not do this.
I think that effected the 05-08's. I know that mine was made after the new coating.
Some say, do the front and rear diff services early, if you get chips out of it, get ready.
75% of all Land Rovers ever made are still on the road...
the other 25% at least made it home.
Old April 19th, 2014, 07:06 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Resurrecting this thread. Great info here but I have a question. Would you buy a 2005 LR3 with 160k on the clock? They are asking 10k for it but it has been for sale for quite a while so I bet I can get it cheaper. That many miles normally would be a red flag but I have no experience with LR3's. If the answer to this question is yes then what would you feel would be a good price? Any advice? Thanks.
Old April 19th, 2014, 10:42 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Well, I have an '05 LR3 with 160,00 miles on it (almost 170,000 now)....
While it's starting to have minor issues (an idler pulley on the belts is going, control arms need replacing again, just did the brakes 2 weeks ago all round), it's going as solid as it was the day I bought it.
10k for it is good to go. Land Rover really hit this model out of the park.
Old April 19th, 2014, 10:46 PM
$10k sounds steep to me. Get a pre-purchase inspection done by a dealer or Land Rover specialist. Also look at the tires, since they go through tires every 20-40k miles and they are expensive tires.
Old April 20th, 2014, 12:20 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Says it has 5 new tires. Also has a roof rack of sorts and a rear tire carrier. I still have trouble buying a vehicle with that many miles but maybe I need to get over that.
Old April 20th, 2014, 07:17 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Tyler, I would highly recommend having it inspected for stuff it currently needs as well as what it will likely need in the near term based on the type of driving and mileage you plan to use it for. If the big picture isn't pretty walk away. At the end of the day these are just about everywhere and odds are equal or better values will always be there.
Clay
lr3
06 LR3 only 56k Campbell For Sale - Vehicles 4 June 20th, 2013 03:38 PM
My 07 Nissan Xterra Jermaine For Sale - Vehicles 3 February 24th, 2013 09:08 AM
'06 LR3 backup chime problem smob Defender Technical Discussions 8 November 16th, 2012 01:58 PM
Wtb 05 or 06 lr3 Campbell Wanted 0 April 12th, 2012 05:52 PM
Center Console Lid for 05 LR3 (black) Brenter Wanted 0 December 19th, 2011 09:04 PM
