LR HD springs sets - Defender Source
Old February 2nd, 2006, 09:32 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
LR HD springs sets
Does anyone run the LR HD springs that RN sells? IF so do they give a mild lift? How Do they ride? I am looking for a set of springs for my Series Coil project and want it to only have about an 1" of lift. THought these might be a good Idea or they could be too stiff. My other choice would be a set of stockers and just add a block if I need a lift. Any Ideas
Legend in My Own Mind.
Old February 2nd, 2006, 09:41 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Randy, i have the OME 751's up front . they gave me about 2" then I added the ARB and 9.5 Warn that brought it down an inch.
The ride is fine not harsh.
Running mediums in the rear.
Old February 2nd, 2006, 09:50 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Randy,
I have a Series coiler and have had a hell of a time getting any info from experience about the spring setup. I just ordered 761, the MD for the front and 764 for the rear. I figure that since it weighs at least 500 lbs less than a D-90, MD would be fine even with a winch since the 2.25 weighs so much less. I had heard from 1 person that LR HD are harsh.
Old February 3rd, 2006, 06:55 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Kevin, let me know how much lift you get with those springs... What do you think? What springs are in your truck now? RN said the LR HD springs ride beter then OME... who the hell knows though..
Just looked at those springs on the EE site. They look like a good setup though. Keep me updated.
Old February 3rd, 2006, 09:21 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Getting the old front shocks out looks like it will be a biotch. I don't know what springs are in it now, whatever ECR put in 9 rusty winters ago. My measurements from the front and rear spring lenghts in the truck now are give or take 10 and 11 inches. I wont have it done for a month or more, I'm picking up the springs at Winter Romp on Presidents day weekend.
Old February 3rd, 2006, 09:29 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
No prob Kevin.. jsut let me know. as for the shocks, cut them off with a sawzall. its the easiest way to get tem if the bolts are all rusted.
caould you send me a bunch of pics of your trucks suspension and how the shock towers fit on the series?
Old February 3rd, 2006, 09:47 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Problem is if you can't get the upper shock bolt off you may need to remove the wing. Between pulling the spring and the shock tower bolts I'm sure I will figure it out. A Series with flex is cool.
http://i.pbase.com/g3/35/542535/3/55641658.DSCF0090.jpg
I'll email you some pics.
Old February 3rd, 2006, 03:39 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
I run the OEM HD Springs. RDS had them at a much better price. I have not noticed much difference in ride from the stock as I replaced shocks to Bilsteins. About an inch with the rubber isolators installed. I like them, but I have set my truck up more biased towards the road.
EwS
George at RDS sent me a sheet with 2 types of springs for 90's listed. 2400kg wuld most likely be best for a 88.
Here you go:
F DS NRC9446 Blue Green
F PS NRC9447 Blue Yellow
RDS NRC9448 Blue Red
R PS NRC9449 Yellow White
I can send you the page if you PM me your e-mail. George did not specify wether these were for only a 90 with a V-8, but that would be my guess. I would think that you could have Rovers North research the springs for an early 90 with a 2.5 which was just a bored 2.25 updated a bit.
eWs
Old February 3rd, 2006, 04:24 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I just looked in my book and those #s above are the stock springs for early D-9o's also.. THose are not the part #'s for the HD springs is it?
Old February 3rd, 2006, 06:57 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
No. Those are for 2250kg. 2500kg appear to be the HD's
Old February 3rd, 2006, 07:10 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I've been looking at the Rover HD springs as well - my D90 SW has an ARB/winch combo on the front and a Tdi under the hood. I'd like about an inch to 1-1/2 of lift to clear the 255/85R16 tires just a bit. I'd be interested in seeing that sheet that George sent you as well - thanks.
Old February 3rd, 2006, 09:22 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Send me a PM with your addy and I'll send it monday....
LR D90 HD rear springs, NRC9462 KevinNY Wanted 2 June 28th, 2009 08:30 AM
LR HD Springs for a NAS 110? R. Kurk Defender Technical Discussions 21 November 18th, 2007 03:02 PM
2x sets of springs Rover- Girl For Sale - Parts 0 March 24th, 2006 01:51 PM
LR HD Front Springs jimbemotumbo For Sale - Parts 0 July 12th, 2005 02:27 PM
ID of LR springs GollyGwagen Defender Technical Discussions 4 April 27th, 2004 07:07 PM
