lowering a defender 90 - Defender Source
Old August 19th, 2014, 02:09 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
hi all,
anyone ever lower a defender 90???
i know i can just buy smaller tires..... but i need to get a defender 3+ inches lower.
anyone ever think / do something like this??
thanks!
Old August 19th, 2014, 02:12 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Install Old springs? A board member has "torched" his springs to get a desired look.
Not quite 3 inches but from a reputable company http://www.alivetuning.com/alive-bou...&product_id=57
------ Follow up post added August 19th, 2014 02:14 PM ------
Originally Posted by d90boy View Post
hi all,
thanks!
Has your client explored a taller garage?
Old August 19th, 2014, 02:15 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
thanks i will take a look.
sadly this garage is attached to his house. =)
Old August 19th, 2014, 02:21 PM
There is no way to spring lower 3" as you would hit the bumps stops. You might get away with 1.5" max on the springs. Maybe another 1.5" with tires if it is on 32s.
If there is money involved, you could build a custom air spring system. There are a ton of threads on AULRO forums on adding them. It is not complicated. This would allow dropping to the bumps stop when going in the garage.
Old August 19th, 2014, 02:22 PM
Call Himalaya
Old August 19th, 2014, 02:23 PM
Himalaya's Avatar
Himalaya
Mark WS
1995 Nas, 86 D110, 97 Hummer H1
We lowered a D90 to fit in a garage.
We ended up lifting the truck as the tires were too big. I know I know we should have known that before hand. BUt the client absolutely insisted on 275 70r20 tires. When completed he drove it for a couple of days and realized we were right. It should not have been lowered.
So we have the as new lowering kit complete. If you want it, i will give you a good deal on it.
It was used for 100 miles lowering suspension kit if you want.
Old August 19th, 2014, 02:31 PM
Running some quick numbers...
572315 - Disco front stock springs would drop around 1.3"
and maybe NRC8055 - Disco rears although it is a bit hard to figure out with the dual rate springs.
Old August 19th, 2014, 02:32 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
good to know. thanks!!!
stay tuned mark. =)
Old August 19th, 2014, 02:38 PM
Okay, I updated my calcs to include both rates and NRC8055 should give around 1.5".
Old August 19th, 2014, 02:42 PM
Himalaya's Avatar
Himalaya
Mark WS
This is as stupid as putting a lift kit on a Ferrari.
-Jeff
Not if you live in NY and want to park inside.
Old August 19th, 2014, 02:45 PM
Himalaya's Avatar
Himalaya
Mark WS
Heres how it looks with 33 inch tires. The wheel arch on the Khan kit is non flexible, so we ended up having to change the suspension to allow articulation to 2 inch over stock lift.
I think with 31 inch tire you should get 3 inch drop. IMO
In photo you can see the difference between stock 90 and lowered. Even with larger diameter tires it still sat lower than Stock.
ID:	101227   Click image for larger version
Old August 19th, 2014, 02:46 PM
Why not throw out the coil springs and convert to an air spring set up?
Old August 19th, 2014, 02:51 PM
Where did I hear that?
Probably because nobody sells a premade kit. You need to custom build your own. I'm surprised nobody has marketed one.
Old August 19th, 2014, 03:10 PM
Originally Posted by rijosho View Post
Call Himalaya
bam.
Old August 19th, 2014, 03:12 PM
Rommel's Avatar
Rommel
Rolf
94/95/97 Many
lower
24" spinners and 30 series tires and you be ready to ROLL !!!!!!!
rolfsauto.com
Old August 19th, 2014, 03:13 PM
Originally Posted by Red90 View Post
Where did I hear that? Probably because nobody sells a premade kit. You need to custom build your own. I'm surprised nobody has marketed one.
Sorry! Jumped over your version of that idea.
Would take an air spring RRC front axle, compressor, air tank, front and rear manifolds.
Our just lower the floor of the garage.
Old August 19th, 2014, 03:14 PM
-Jeff
X2! This wreaks of NBA narcasism
Mark Kellgren
KM4BOR
Old August 19th, 2014, 03:19 PM
Used RRC pre EAS springs and disco 1 size tires should get you close to 3in below stock. How tall is the garage door? Note with smaller tires the speed limiter will kick in early and speedo will run fast. You would need the gear out of the row t-case (ROW d90s have disco I sized tires stock).
Old August 19th, 2014, 03:26 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
hi all,
thanks!
has it come to this Keith?
Why not stick a SBC in your mint Dino while you're at it!
I'm just bustin' your balls, but I wish things were selling in such a way that you could refuse to ever take this person's phone call again for suggesting such a ludicrous idea. Like the "Soup Nazi" but for Defenders.....The Defender Nazi.
No Defender for you!....EVER
Old August 19th, 2014, 03:27 PM
Mark Kellgren
KM4BOR
90, defender, defender 90
Lowering Gas Tank J. Andrew Defender Technical Discussions 6 May 11th, 2010 01:02 PM
Swing away/lowering tire carrier--overkill? MUDSUX Misc. Chit-Chat 14 March 5th, 2010 02:04 PM
sway bars lowering blocks or off rgrrvr Defender Technical Discussions 14 September 5th, 2007 09:19 PM
