Looking for a USB Hub and ideas - Defender Source
Old June 12th, 2012, 04:25 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I'm looking for a four spot USB Hub that I can hard wire to be always on. Has anyone found one that holds up to some truck abuse? I want it hard wired everything I find online is a plug in a cig lighter type.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old June 12th, 2012, 04:34 PM
http://www.amazon.com/Blue-Sea-Syste.../dp/B0082CXEI8
Old June 12th, 2012, 04:43 PM
D110DC's Avatar
D110DC
Pete
66 SIIA, 70 IIA, 97 D90
USB hub
Try this: http://www.kensington.com/kensington...rt-usb2-o.aspx
Pete
1966 ECR Series IIA
1970 Series IIA (Stella)
1997 D90 ST
2011 LR4 HSE
2010 Range Rover Supercharged
Sadly gone (some more sadly than others):
1983 D110 Double Cab 300 TDi
1989 RRC
1996 D1
2006 LR3
2008 RR
Old June 12th, 2012, 05:28 PM
I ended up with a product by magna dyne that plugs into an outlet but once I'm planning on getting another unit cut the plug off and wire directly into the vehicle. Provides two USB only and two outlets. I'd like more outlets of course!
Old June 12th, 2012, 05:32 PM
I think I have the same thing. Removable though. My radio has a USB as well, so in all I have 3 USB ports.
Old June 12th, 2012, 05:48 PM
Yes, around $2 on eBay for flush mount 12V cigarette lighter plugs that provide two USB outlets. It ends up being more flexible overall as you can pull the adapter and use the 12V outlet for other things.
Old June 12th, 2012, 05:54 PM
I have gadget spagetti ... Iphone, GPS, ECUMate, occasionally charging my bike GPS ...
Old June 13th, 2012, 09:54 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
I want to say bits4landys on ebay.co.uk is selling a USB/charger setup you might want to check out.
Old June 13th, 2012, 10:03 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Not a bad piece of kit:
http://www.ebay.co.uk/itm/Land-Rover...item4ab51a1ea5
Semper Fi!
Old June 13th, 2012, 10:53 AM
I thought this looked pretty good, too. Just put those removable USB docks in the sockets.
http://cgi.ebay.com/ebaymotors/ws/eB...iewitem=#v4-37
Name:	Double socket.jpg
