Looking for a ROW fuse box diagram - Defender Source
Old April 11th, 2013, 11:08 AM
BEIS's Avatar
BEIS
RYAN BEIS
D110 Soft Top with full rollcage
Looking for a ROW fuse box diagram. I know my other trucks always had a sticker that indicated what each fuse was linked to. Can anybody snap a picture of their fuse box sticker or diagram for me? Thanks!
I have the glass fuses and the box is located just forward of my '97 auto shifter, so, the fuse box might be the same as a '97 NAS fuse box. Not sure though.
-Ryan
Old April 11th, 2013, 11:49 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Will send a pic this eve when I get home if you still need.....
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old April 11th, 2013, 12:18 PM
BEIS's Avatar
BEIS
RYAN BEIS
This looks like what I'm looking for. Hope this helps others out. Thanks!
-Ryan
Old July 11th, 2013, 07:17 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Which one of these fuses is for the license plate lights?
Old July 11th, 2013, 08:18 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
left hand side light (5a) on mine
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old July 11th, 2013, 09:12 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Really depends upon the year and model, SW etc. They made many different looms for the same year not to mention different years and the fuse panels could be different. The only way to be sure is to test everything out and trace the wire colors.
Old July 11th, 2013, 09:51 PM
josh-man's Avatar
josh-man
joshua
Were the MOD early defenders the same?
Old July 11th, 2013, 10:40 PM
Josh
It is going to be one of the 5a tail light fuses. If your tail markers DON'T work start pulling till you find one burned. If they are all good you need to start tracing the red/orange wire back to where it tap into the left rear marker light according to my MOD schematics. They are all together behind where the plate light bolts onto the body. Also check that you have a good ground off of the black lead.
Old July 12th, 2013, 06:37 AM
Capt Milks's Avatar
Capt Milks
No, you they different versions. You also had some MOD trucks that were either regular ROW, British specific or MOD specific.
As stated above you can start tracing the wiring. On the light circuit you have it in the switch, hazard switch, front loom and chassis loom. If it had the center dash light control switch it has it there also. The headlights could have a different fuse, LH and RH, as the running and turn, brake lights. If you loosen the fuse panel you can get a good look at the back side and the wiring colors. It will help you label a few of the fuses for a good start.
Old July 12th, 2013, 06:44 AM
Would it help if OP posted details of his truck. The variations in spec are enormous.
Old July 12th, 2013, 01:08 PM
josh-man's Avatar
josh-man
joshua
Originally Posted by javelinadave View Post
Josh
Thanks. That license plate wiring is really not very secure. Once I change the fuse, I think a dollop of solder would be better to hold those wires to the connections on the plate light bracket IMO
Old July 12th, 2013, 03:36 PM
josh-man's Avatar
josh-man
joshua
Josh
HUGELY helpful Dave, thanks a ton!
fuse box diagram and amp values? Gkase Defender Technical Discussions 0 April 7th, 2010 02:22 PM
new fuse box cover mattdh For Sale - Parts 10 March 29th, 2006 01:24 AM
Fuse Box easy to replace? waveridin1959 Defender Technical Discussions 7 November 5th, 2005 08:11 PM
Engine Fuse Box Cover thug1313 Wanted 3 April 20th, 2005 07:26 PM
