Look at these little beautys (aux heater blowers from UK) - Defender Source
Old February 25th, 2015, 02:05 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Heaters - Water : T7Design.co.uk, Lightweight Kit Car Heaters
Just stumbled upon this but it seems like an interesting way to add an aux heater to your truck in a compact size, matched with a webasto coolant heater you might have a nice way to preheat your 90 all over and keep the rear passengers alive
Never seen it before so I thought I would share
Old February 25th, 2015, 04:08 PM
When I first read your post I thought it was rover specific. These are universal application and there's many supplies of systems like that here in the US you can source for much less, but still good timing for a post like this. I am definitely doing the heater fan upgrade this spring after the big chill is gone. if that doesn't seriously increase my output, then an aux may be the way to go.
Mark Kellgren
KM4BOR
Old February 25th, 2015, 05:33 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
sorry to hi jack - but i am about ready to add an aux heater or something like that to keep warm here in boston. any thoughts, suggestions?
thanks!
Old February 26th, 2015, 12:00 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I liked the compact size and high cfm of the units, thats why I posted them, though I agree with you there are other options stateside
Old February 26th, 2015, 12:08 PM
thanks!
There are too many to choose from. A good place to start for universal auxiliary heaters is ebay. Search on 'auxiliary heater". They are common for adding to buses, vans, tractors, etc. Just figure out your btu requirements, budget (figure $200ish) and configuration/mounting position (which will dictate where you want the heater hose connections in relation to the outlet.
Here is just one example: New 20 000 BTU Auxiliary Heater Used in Fleet Vehicles Truck Bus Van 12 Volt | eBay
Mark Kellgren
KM4BOR
Old February 26th, 2015, 12:11 PM
BlackField's Avatar
BlackField
Oscar
D110
I'm working on one right now and those look way easier to install than the AUX Heater/ AC combo I'm installing.
Old February 26th, 2015, 12:14 PM
AC makes it quite more complicated.
Mark Kellgren
KM4BOR
Old February 26th, 2015, 12:44 PM
aosias's Avatar
aosias
Alexandra
1995 D90
My first 90 had an aux heater that was switched on the console to the left of the steering wheel. I've yet to see another one like that. The vent was behind the driver's side seat in the floor. Truck came with it so I never knew anything about it.
Old February 26th, 2015, 01:33 PM
thanks!
Here you go Keith!
Heated Clothing - Electric Clothing - Heated Socks & Heated Gloves
Whoops...meant to post this...
http://www.summitracing.com/search/p...ers&kr=heaters
Old February 26th, 2015, 01:44 PM
Does anyone know the cfm and btu rating of the stock defender heater as a point of comparison?
Mark Kellgren
KM4BOR
Old February 26th, 2015, 02:00 PM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
John aka Red90 has a good write up
Old February 26th, 2015, 02:35 PM
I measured 160 cfm and 10000 btu/h with the stock system and the lower deflectors removed.
I measured 240 cfm with it out.
Old February 26th, 2015, 02:47 PM
scrubs
henery
1974
Red Top also has a nice line of auxiliary heaters
Old February 26th, 2015, 03:22 PM
damn. 10k btu sucks when comparing to any of the aux units that are in the 12-20k range.
did you have the enlarged bulkhead hole when you did the 160/240 measurement?
Mark Kellgren
KM4BOR
Old February 26th, 2015, 03:36 PM
No. However in my opinion the bulkhead hole is not restrictive with the stock heater. The wing intake and the dash vents are the restriction points.
Old February 26th, 2015, 03:38 PM
Keep in mind any specs from a new heater is the best case and it will be worse installed.
The stock heater was 240 cfm outside of the truck and would probably do 15000 btu/h.
Old March 16th, 2015, 01:46 PM
BlackField's Avatar
BlackField
Oscar
D110
According to the manufacturer the "3.5kw Lightweight Heater" should put out about 12000 BTU. I have one sitting in the garage now. Its a nice little unit. It will likely be warm by the time I get to test it, but it looks like a good add on for cargo area heat.
Old March 16th, 2015, 03:21 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Honestly I thought the compact size on these would make them ideal for mounting in the wheel well of the vehicle to reduce interior space demands.
interested with your experience as I have seen similar products stateside but the overall size of these makes them desirable
heater
D90 part # needed for aux heater kevinoconnor Defender Technical Discussions 0 February 11th, 2011 10:58 PM
Aux Heater? NASD90 Defender Technical Discussions 59 December 21st, 2010 12:24 PM
FS Defender aux heater ECR For Sale - Parts 9 March 31st, 2009 10:24 AM
aux heater in defender 110 d90boy Misc. Chit-Chat 3 October 10th, 2007 09:24 AM
Removing aux heater core cpk Defender Technical Discussions 9 March 18th, 2007 07:34 PM
