locking rear door - Defender Source
Old May 24th, 2014, 10:34 PM
ymc226
Lawrence
1995 D90 SW NAS
locking rear door
I'm having trouble locking the rear door on my '95 D90 NAS SW.
Not using the ignition key which I was advised to use only in starting the car but using the shorter door key. This key easily locks/unlocks both doors but I have to work to lock the rear door. I end up not knowing what I did to make it work as I seem to jiggle it clock/counter clock wise many times until it locks. Is this normal?
Should I use the ignition key instead?
Old May 24th, 2014, 10:37 PM
Try squirting some lube into the lock itself. You may also need to lube the locking mechanism too.
Old May 24th, 2014, 10:45 PM
ymc226
Lawrence
1995 D90 SW NAS
Thanks, I'll squirt some DW-40 into the lock and see if that works. How do I lube the locking mechanism?
Old May 24th, 2014, 10:55 PM
I would use lithium grease instead of WD40 myself but somebody else may chime in with a better suggestion.
As for lubing the lock mechanism itself squirt some behind the part that grabs the hasp on the body and try to squirt some inside where the tab is that you move up and down to lock the door. I would then rotate the key a few times to work the lube in along with moving the interior locking tab up and down (insert high school sexual humor here) and that should take care of it. My guess is it is just full of road grime and old grease.
Old May 25th, 2014, 01:36 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Dw40 is a penetrating oil, not a lube. In fact it does a very good job of acting as a solvent and washing away any lube you do have in there. And then it evaporates to give you a metal on metal situation. You can get Teflon lube sprays that work much better as a lube but I'm not sure that would be best in that case. Probably lithium grease would do the trick as mentioned.
Old May 25th, 2014, 01:40 PM
ymc226
Lawrence
1995 D90 SW NAS
Thanks Dave and Mark. Just went to Home Depot and picked up a can of lithium grease.
Old May 25th, 2014, 03:41 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
you said up and down....
Old May 25th, 2014, 05:51 PM
ymc226
Lawrence
1995 D90 SW NAS
That did the trick. Door now locks and unlocks easily. Thank you very much.
Old May 25th, 2014, 06:03 PM
jafir's Avatar
jafir
Jafir Elkurd
They advertise it as a lubricant.
http://www.wd40.com/files/images/graph3in73498156.png
Old May 25th, 2014, 08:11 PM
Originally Posted by jafir View Post
WD-40 is a very very light lubricant ... not really suitable for maintaining defender locks where the lock shims are held in place with grease ... different lubes for different situations ...
door, rear door
Land Rover ARB locking Front and Rear Diffs - $2700 themaxx The Flea Market 3 March 11th, 2008 11:25 AM
Wheel locking driving at top speed. MattD Defender Technical Discussions 12 February 19th, 2007 04:54 PM
Need replacement locking gas cap vnrover Defender Technical Discussions 17 April 10th, 2004 04:29 PM
land rover OEM locking wheel lugs mpodgorski For Sale - Parts 2 December 29th, 2003 12:22 PM
Rear door remote locking Ray Defender Technical Discussions 3 November 23rd, 2003 11:50 AM
