LHD MudUK Tunnel Trays are ready! - Page 2 - Defender Source
Old August 12th, 2008, 02:52 PM
cabell's Avatar
cabell
Cabell Crowther
So you've been prequalified as an EE photographer? Kudos!
Old August 25th, 2008, 11:35 AM
Update. I have the new tray installed. Will post pics in next day or so. Initial impression...me likes!
Couple quick points on this from initial experience. First, I think off roading or on corrugated roads, it would likely bounce around a bunch. there is a little slack on it, and it is light. If you just had a 12 oz soda in it on that bumpy road, I think it would spill. Some velcro or some mounting tabs would resolve that (easy enough to fab). Second, if your parking brake is stretched enough that it would pull up to vertical, then it will hit the beverage holder end of it, and twist to the side, likely spilling a drink when you did it. I am overdue at adjusting my parking brake. If you do have it adjusted properly, you won't have this issue, as up to about 45 deg angle, the parking brake is clear of the tray.
It really is handy to have a place to through things, and regain some usefullness out of that originally unused real estate. And with the tuffy box, I have 4 beverage holders at my disposal! Think about that when you are sent out to bring back coffee on a Saturday morning!
Old August 31st, 2008, 04:03 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
I tried installing mine yesterday and wonder if I'm missing something...it sure seems wobbly to me...Mark, do you know if its supposed to be a press fit on the shifter base area somehow? Not sure I would really trust a drink sitting on it even on a city street let alone off road...but I'm probably not getting how it gets properly seated...
George
Old September 3rd, 2008, 12:18 PM
Sorry I missed this. It is supposed to be press fit using the shifter base, but mines also a little loose. I had the same concerns for off road, and when my unadjusted parking brake hits it. Other than that it seems fine. I'm going to figure some way of securing it. shouldn't be too hard.
BTW, my wife got in my 110 for the first time since I had it, for a 2 hour trip, and when she saw it she said "is that new? I like it!"
Old September 10th, 2008, 02:36 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Tunel Tray Installed Pics?
I'd love to see any installed photos of the LHD tunnel tray and the minor fitment/security fix ideas. I'd love to get one if it really works well. Is EE the answer now? What will the total cost be? Thanks again. - Dave
Old September 10th, 2008, 10:13 AM
Here's mine taken from this morning. I'm working with MudUK right now to resolve the "slack" issue surrounding the gator. It is supposed to be a snug press fit around the gator that keeps it from moving at all. Apparently it fits fine around euro LHD Defenders they did the testing on, but the NAS gators seem to be a bit smaller. The slack is about the size of a ballpoint pen on both axis. MudUK is holding off on all NAS shipments until they can resolve the problem. I'm actually quite happy with the product, and the throw space in the gator well is a huge value add. MudUK are perfectionists though, so standby. You'll be the better for it.
Sorry about the lighting. I enhanced as much as possible, but it's overcast here today.
Name:	Mud UK tunnel tray.JPG
ID:	15194   Click image for larger version
Name:	MudUK slack small.JPG
Old September 10th, 2008, 10:35 AM
Gkase's Avatar
Gkase
George Kase
believe it or not, that is not my issue. I can't get the tray to seat all the way over the gator...the tray hole seems to small to fit all the way down. I just havent' had the time to inspect it closely and determine why...I suspect my gator may not be mounted correctly or something...
Old May 14th, 2010, 01:49 AM
how did you install it with the Tuffy box - remove it and then reinstall after the tunnel tray?
asking b/c i have on now and was wondering about the install. test fit indicated that there was not enough room for both. which would be a bummer.
95' D90 - daily driver..
Old May 14th, 2010, 09:35 PM
My tuffy is actually installed an inch or two farther back than their directions state. I did it for other reasons, but the muduk tray fits perfectly. I'll try to get a pic posted.
Old May 14th, 2010, 10:47 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Mine fits well too. No space issues with the Tuffy box.
Old May 20th, 2010, 07:02 PM
humm i'll try to move the tuffy back in that case and see what happends - need and inch or so to make it fit.
i just recieved the version with the 3 outlets in it
edit -> looks like you tuffy cup holders overlap the console on top is that correct? or just the angle
lhd, mud
1995 DiscoTrail Ready ron For Sale - Vehicles 4 February 7th, 2006 04:03 PM
1994 Land Rover Discovery, ready for off road SBA For Sale - Vehicles 4 August 24th, 2005 11:28 AM
Expedition Ready Range Rover RedRhinoProducts For Sale - Vehicles 0 September 19th, 2004 01:12 PM
1995 Discovery 300TDI, Trail Ready.... Joe B For Sale - Vehicles 1 June 23rd, 2004 06:26 PM
