LHD Conversion - Defender Source
Old October 18th, 2009, 08:25 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Talking LHD Conversion
Half way there... LOL!
Old October 18th, 2009, 08:41 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Old October 18th, 2009, 08:45 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
You're almost there! Keep up the good work
Old October 18th, 2009, 09:03 PM
That's excellent!
Old June 14th, 2010, 09:46 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Progress
Finally made some progress on my "LHD Conversion" which is now much, much more...
ID:	28551   Click image for larger version
ID:	28553   Click image for larger version
Old June 14th, 2010, 11:55 PM
, I notice in the first pic it does have a LHD steering box!
Old June 15th, 2010, 12:22 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Good eyes Ron... did you notice the ABS RRC front axle that I had to swap out later for a non-ABS D-90 axle? That was a hard lesson. It goes quicker the second time though...
Old June 15th, 2010, 11:16 AM
No, why? They both would work.
Old June 15th, 2010, 09:12 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
You're right, it did bolt up, but the ABS axle had a wheel speed sensor protruding from the top of the upper swivel pin. It was in the way of the bracket that holds the brake line, and removing it left a hole into the swivel ball. I thought I would just swap the non ABS swivel pin from the 90 axle I had, but when I tried that it was different (different diameter and different bearings). There might have been an easier way but at that point I just put the 90 axle in.
Old June 15th, 2010, 10:13 PM
Yes, there was an easier way.
Old June 15th, 2010, 11:10 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Man, I should have consulted the expert! Feel free to share what it was, because I still have the other axle and would like to use it in something that doesn't have ABS...
Old June 16th, 2010, 01:03 AM
Well, I have not looked at it up close, I would either use the axle bracket off the new axle or take out the wheel sensor and cut the end off it and then right stuff it in flush with the outside. I can't believe it is insurmountable. I know Doug C has done a number of these swaps.
Old June 16th, 2010, 07:16 AM
oilburner's Avatar
oilburner
JL
large pile of parts
The non-abs stuff is stronger though, if that's any consolation for your busted knuckle blues.
JL
Old June 16th, 2010, 09:30 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mike, you can buy the top dust shield bracket for a d-90. They cover the holes. I did this on the series coil truck build. I also siliconed under it to keep the water out.. At least you are using all stock rover parts and once completed, you could never tell...
Legend in My Own Mind.
Old June 16th, 2010, 10:54 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Randy, any idea on part number or the source you landed them from? I still have my ABS sensors post engine swap, ziptied to the axle. Would love to clean that up.
Old June 16th, 2010, 01:14 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Ron/Randy,
I thought about doing something like you suggest, but wasn't completely comfortable with it. Also, the RRC axle I had was unknown mileage and the 90 axle only had 70,000 on it so I decided to swap it out (I didn't have the 90 axle when I first put the RRC in). I'll do something like that when I use that axle.
Old June 17th, 2010, 12:07 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I will get the parts #'s for you later today.
conversion, lhd
RHD to LHD conversion question Gkase Defender Technical Discussions 14 September 14th, 2008 08:01 AM
LHD Dash parts for conversion Uncle Douglas Wanted 6 August 1st, 2008 02:17 PM
RHD to LHD conversion evilfij Defender Technical Discussions 1 December 8th, 2006 02:21 PM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
