Let the wave of trucks from Sandy begin - Page 2 - Defender Source
Old January 2nd, 2013, 07:42 PM
Originally Posted by Neil McCauley View Post
What if you just disconnected all the wiring, blow each side out with air and clean with brush/sand paper and apply di-electric grease liberally to all the contact points and then restart with new ECU's/sensors etc? (Providing the wiring contacts are still good)
I'll bet there is a good amount of salt water that got into the gas tank, engine, etc. etc. gaskets may quickly corrode, and that any wires that last in the short term will likely corrode fairly quickly in the not-too-long term, since the wiring harnesses seem to corrode even without being submerged in seawater...
Old January 2nd, 2013, 07:48 PM
The salt water has wicked up inside of every wire, connector, motor, switch. All electrical parts; wires, lights, dash, heater air conditioner, you name it, are now garbage or soon will be.
Salt water has infused the seats, and all the soft materials including insulation. It has ruined the brake system too, and the engine and transmission.
Not much to save there.
Old January 2nd, 2013, 07:50 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I forgot to mention dumping/flushing/filling any / all fluids. mabye an engine re-seal with heads etc. I'd try it since you'd have nothing to lose by then except for a few hundred bucks.
Robert Deniro
Old January 3rd, 2013, 07:25 AM
Does any of this vary on how long the car was actually submerged?
The electronics I could see having to be replaced, but shouldn't the frame easily withstand a week underwater without much happening to it?
Old January 3rd, 2013, 08:07 AM
Ed, when a boat, or in this case, a car, goes under, a rapid sequence of salvage must take place immediately. How long it has been under is a concern, but more important is how long it has been out of the water and what has been done to it. The engine(s) must be drained of coolant and oil. The fuel system has to be flushed (which in the case of the in-tank fuel pump means replacing it, but the wire harness is effed, so that has to be replaced first before running the new fuel pump. And oh, all the other electronics are fried so new ECU, injectors, and MAS and....) and the engine started right away to drive out the moisture. Several oil changes must be done with the engine getting up to temp between each one. Ditto the gearbox and transfer case.
With this being an aluminum engine, the cooling system will also need several flushes or else the salt will go after the alloy and you'll get aluminum salts clogging up the passages.
About all that is of any value on a vehicle that has gone into salt water is the frame, body panels and maybe the axles and suspension if they all get a huge flushing with clear fresh water. All else is not worth the effort required to recover it if it has been more than 24 hours before remediation.
A boat is usually a lot less work to recover due to the fact that most of its systems are meant to live in a salt water environment, even short submersion, and it has fewer systems. Usually the electrical gizmos, wiring and all the living and comfort goods get tossed. The engines "pickled" right after recovery. Replacing those items is cost effective.
In many cases it is actually better to leave the thing under until all is in place for a full recovery. Once it is out of the water and in the air, the oxygen goes to work. In the case of the storm submersion, the water went away rather quickly. This means that unless someone jumped on this the next day and started the long and laborious process of reclaiming it, it is a goner.
Old January 3rd, 2013, 08:21 AM
And in this case the NAS Soft top cage, Badger top (if still in good working order with good windows - not sure what the salt does to that in the short term or if they can be salvaged easily with water and polish), VIN, 3rd brake light bar for Jeff Briggs, etc.
Old January 3rd, 2013, 09:58 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
So it does seem like a trip to Raush Creek is needed to clean the truck then!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old January 3rd, 2013, 10:03 AM
At least Rausch is fresh water.
Old January 3rd, 2013, 10:45 AM
Bill, thanks - sounds like some work!
Old January 14th, 2013, 06:37 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Here is another one, 1995 AA Yellow. 89k miles and it says it starts.
https://www.iaai.com/Vehicles/Vehicl...34&RowNumber=1
VIN:SALDV2285SA956470
VIN Status:OK
Body Style:WAGON 2 DOOR
Vehicle Class:Mini Sport Utility
Series:90
Manufactured in:UNITED KINGDOM
Exterior Color:YELLOW
Interior Color:BLACK
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old January 14th, 2013, 06:41 PM
As I said to the guy whose D90 got flooded in Ike. A flood is like a trip to the pine barrens for a defender.
Old January 14th, 2013, 07:12 PM
I've said the same. We flood ours at Rausch - on purpose - every couple months!
Old January 14th, 2013, 09:57 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
hahahaha, mine should have monthly salvage titles at that rate.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 14th, 2013, 10:15 PM
Outstanding. Is that a POE?
Old January 14th, 2013, 10:29 PM
Kelbo's Avatar
Kelbo
Kelly
'86 110
Awesome.
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
Old January 14th, 2013, 11:46 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
These trucks would be an OK deal at $5000-7000.
Old January 14th, 2013, 11:48 PM
bjf's Avatar
bjf
barry f
94 ST #395
Come on. They are worth that in parts alone.
Old January 15th, 2013, 12:03 AM
Hell, a good LHD dash setup is worth $2k+ itself.
Old January 15th, 2013, 09:38 AM
87 D110 (Ruby)
Here is another one...out west...seems as if this one could possibly go for single digit 000's...maybe been moded a lot judging by Disco seats
https://www.iaai.com/Vehicles/Vehicl...50&RowNumber=2
Old January 15th, 2013, 09:54 AM
And the rollcage - can't tell if that's a burned up cage or not.
High Mileage Trucks aosias Misc. Chit-Chat 35 April 19th, 2012 07:53 AM
TD5 trucks to the USA Trek Jon Misc. Chit-Chat 15 August 31st, 2005 03:42 PM
Do the wave .....! ?? Rover- Girl Misc. Chit-Chat 23 July 20th, 2005 11:10 AM
Scorpion racing Rear upper shock mounts for stock trucks! dmarchand For Sale - Parts 2 July 8th, 2004 12:57 PM
Holy Dump Trucks! Mike Hippert Misc. Chit-Chat 2 June 27th, 2004 08:23 PM
