LED light bar recomendations - Page 2 - Defender Source
Old January 4th, 2015, 06:15 PM
Rover110
Steve
1993 Defender 110 NAS #472
I looked at Baja. Would love to but bank wouldn't approve
Originally Posted by TMWTP View Post
I used to work in the LED industry. Not in this application, but one with similar technology. The best brand, imho, is Baja Designs. But, they're expensive. Given how long LED 's last, and how many hours they are used in an automotive application, there isn't much value in loading tons of tech into a light that will probably get destroyed. I have a couple of Lifetime bars on my buggy with a couple Xtreme LED pods. My 110 will get the Xtreme treatment all the way around.
Old January 4th, 2015, 06:23 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
You get what you pay for with a lot of the LED's that are out on the market these days. The budget China bars use lower quality LED chips that are 'seconds' which are less consistent in color and light output, which helps keep the prices down. While they may be advertised as having CREE LED's, it's not a 1:1 comparison with what the high end bars are using.
Reflectors also make all the difference in the world, as they're what aim the light down range. The cheap bars often use poor quality reflectors, both in design and reflective coating, which throws a lot of light to places that are of no benefit to the driver, and can also result in 'hot' or 'cold' spots.
The above, plus the overall quality of construction and thus longevity of the bar make the difference between an auxiliary light that is decent, or downright awesome.
I'm a dealer for Baja Designs and can offer some solid discounts over most of the guys out there. The performance their products offer is unreal, and I have only had a single QC issue with a light that was sealed improperly which they replaced with zero questions asked. I'm a fan.
-Ash
Geared Restoration Co.
352-572-3236
Old January 4th, 2015, 06:29 PM
MM3846's Avatar
MM3846
95 D1
Originally Posted by ArmyRover View Post
They all come on at the same time, usually the spots are in the center of the bar, and the floods are on the ends. So you get a great spread of light in front of you.
Yup.
Baja designs is no way worth the giant step up in price.
Old January 4th, 2015, 06:39 PM
TMWTP's Avatar
TMWTP
Jon
1989 One Ten
What Ash said is 100% spot-on. They call it "binning" in LED-speak. You can advertise it as a Cree XPG, or whatever, but if it's not out of the best bin (more $$), the quality won't be consistent, nor will the color.
What makes Baja more expensive is the thermal protection built into the circuitry. Heat kills LEDs. Having active thermal management will extend the lifespan. Using higher quality LEDs will yield more lumens with the proper color. IIRC, Baja uses a lot of TIR (total internal reflector) lenses. These are more efficient, and of course, more expensive. The products I sold used these same technologies with great success.
For my buggy application, there is a high probability of roll-over and light bar damage. I'd rather not destroy a big-dollar light bar. I can afford to replace the cheaper ones if I have to.
It's all a trade-off. You can compromise on color, longevity, and efficiency for price. You always get what you pay for. The question is, do you get more than you need.
'14 F250 dd tow rig
'17 Discovery (wife's dd)
'88 110 under the knife
'12 Rockware 3-seat rock buggy - FOR SALE!
'13 LR4 - FOR SALE!
'83 110 - FOR SALE!
Old January 4th, 2015, 07:47 PM
They're prime targets for street theft so make sure you have them secured.
Old January 4th, 2015, 07:53 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
A quick little spot weld works pretty well if you're in a bad area. Most light bars let you replace the hardware so you can use new bolts if you have to take it off.
Old January 4th, 2015, 07:56 PM
Ash's Avatar
Ash
Ash Heller
There's also security hardware out there to make it a bit more difficult.
-Ash
352-572-3236
Old January 4th, 2015, 08:03 PM
Rover110
Steve
I'll look at Baja again and make contact.
Originally Posted by Ash View Post
You get what you pay for with a lot of the LED's that are out on the market these days. The budget China bars use lower quality LED chips that are 'seconds' which are less consistent in color and light output, which helps keep the prices down. While they may be advertised as having CREE LED's, it's not a 1:1 comparison with what the high end bars are using. Reflectors also make all the difference in the world, as they're what aim the light down range. The cheap bars often use poor quality reflectors, both in design and reflective coating, which throws a lot of light to places that are of no benefit to the driver, and can also result in 'hot' or 'cold' spots. The above, plus the overall quality of construction and thus longevity of the bar make the difference between an auxiliary light that is decent, or downright awesome. I'm a dealer for Baja Designs and can offer some solid discounts over most of the guys out there. The performance their products offer is unreal, and I have only had a single QC issue with a light that was sealed improperly which they replaced with zero questions asked. I'm a fan. -Ash
Old January 4th, 2015, 08:12 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
-Ash
Ash, you're too pampered down there in the south. Up here any and all hardware just corrodes to the point of making it impossible to remove...
Old January 4th, 2015, 09:05 PM
Ash's Avatar
Ash
Ash Heller
Well you're not doing yourself any favors with that MIG gun! Haha I used to weld the mounting hardware on all of my winches before they finally came out with security hardware for them. It certainly works.
-Ash
------ Follow up post added January 4th, 2015 09:14 PM ------
Here's a terrible series of iPhone pictures that I took a while back, demonstrating the Baja Designs 15" OnX bar on top of a pair of JW Speaker LED headlights. The JW's have a fantastic low-beam, but the high-beam leaves an awful lot to be desired, which is why we supplemented them with the bar.
Low:
High:
High with the bar:
And just for fun, this is their 50" bar with no other lights on.
352-572-3236
Taveling to England - Looking for Recomendations Stmpede Misc. Chit-Chat 28 August 5th, 2013 12:41 AM
Slider recomendations? pacificwildfire Defender Technical Discussions 101 June 1st, 2011 01:02 PM
Spray Paint Recomendations everglades Defender Technical Discussions 9 December 19th, 2007 03:13 PM
Any new battery recomendations? mountaintek Defender Technical Discussions 20 November 21st, 2007 02:07 AM
NAS 110 Suspension Recomendations NAS 110 Defender Technical Discussions 9 January 11th, 2006 10:12 AM
