Latest question. Thread size on 3.9 water pump for fan clutch? - Defender Source
Old January 29th, 2005, 06:20 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I found flex-a-lite makes a fan adapter for 30mm x 1.5 threaded fans in both left and right handed thread.
Coincidentally, I also need to replace a blown clutch and fan with cracked blade.
Before I take a chance on ordering a part, is there anybody that can verify the threading on the nose of the water pump?
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 29th, 2005, 09:03 PM
Hans's Avatar
Hans
Hans Haase
Further research has provided some non LR options.... if I ever get a chance to measure one. The chart on this link really makes me think we have 30mm noses on the water pumps. I will continue to look into this, I just wish I had something to measure the darned thing.
http://www.truckair.com/tap/catalog/SECT5/FANCLU~1.PDF#search='fan%20clutch%2030mm'
My oil line fix
clutch, fan, fan clutch, water, water pump
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
Water Pump Help!!! Dfndr90 Defender Technical Discussions 14 May 3rd, 2005 11:51 AM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
