Land Rover kills driver on his way to propose to girlfriend - Defender Source
Old March 19th, 2012, 04:31 PM
I don't know if anyone has seen this yet, but it looks like a man named Adam Goodsell from Salt Lake City, UT was on his way from picking up an engagement ring last week, when his Land Rover malfunctioned - in his call to 911 a moment before the crash he says his brakes weren't working and his accelerator was stuck down. From the photos, it looks like a Land Rover Discovery II by the wheels. Really sad news. Not sure if there's a way to know that they'll malfunction, but if you have a similar system and there's a way to check, you may want to do so.
http://www.deseretnews.com/article/8...ter-crash.html
http://www.nydailynews.com/news/nati...icle-1.1046888
Old March 19th, 2012, 04:40 PM
I never understand these kind of incidents. Calling 911 would come far behind actually trying things to rectify the situation or putting my seatbelt on (although mine would already be on). But if my brakes went out I'd try things like drop it into a lower gear and apply the hand brake, or just shut the vehicle off. Of course he could have tried all these things before calling 911, but why no seatbelt?
Originally Posted by pendy
I'm here for the D's
Old March 19th, 2012, 04:41 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Um...
"The man was not wearing a seat belt when his vehicle left the roadway, ejecting him."
Quick note. If you gas pedal ever sticks do the following:
1 - Put the vehicle in Neutral
2 - PUT ON YOUR SEATBELT!
Sorry for the loos...but more sorry that this would have been totally avoidable.
They should teach a stuck pedal in drivers ed.
I would also bet that the brakes might have failed due to overheating from trying to brake against the racing engine.
My wife had a similar thing happen in our 97 Range Rover and she could not slow down...luckily she had a 60 miles of interstate to call me and have me help her. That engine had two throttle cables one for the pedal and one for the cruise. If the retaining clip broke on the pedal cable it would slack and fall out under the tension of the cruise cable...when it fell out, it jammed it at 3/4 throttle.
She now knows what to do...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old March 19th, 2012, 04:52 PM
Actually, it looks like a Range Rover P38 based on the location of the gas cap door. I thought those wheels only came on the Borrego for the Range Rover P38 and more commonly on the Disco II.
------ Follow up post added March 19th, 2012 04:57 PM ------
Absolutely!! This would be way more useful than how many feet you're required to park away from a stop sign.
Definitely possible.
Um...
Wow, so maybe it IS a Range Rover P38 thing - as I looked at the pic again, and flipped the photo and it immediately looked like a P38 instead of a Disco II.
Old March 19th, 2012, 05:03 PM
The throttle bodies on GEMS trucks (probably bosch too) get build up and stick (thanks emissions systems). Pretty sure cleaning them is in the recommended maintaince. I had this happen with some regularity on a 1996 DI. Just pop it into neutral and let it bounce off the rev limiter. BTW, no way his "brakes failed" as he probably could not brake enough to overcome the engine.
People should learn what to do when a throttle sticks. I know I was taught in drivers' ed.
Old March 19th, 2012, 05:12 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
On our P38 it definitely was a mechanical failure of the cable retainer...I ended up zip-tying the cable and telling the wife to not use the cruise until the parts came. Thought is was a pretty serious design flaw...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old March 19th, 2012, 05:20 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I thought this was an article about Brandy.
Robert Deniro
Old March 19th, 2012, 05:23 PM
Sad to hear.
Silly as it sounds I have thought of "worst case situations" with the 200tdi. The engine could run away with its own oil or the injection pump could get stuck/go fubar and the fuel stop solenoid could fail. The clutch pedal could stop working simultaneously. The only thing left to do would be to drop into neutral.
If the gearshift lever fails then I drop the LT230 into neutral. Failing that...well...
Old March 19th, 2012, 06:13 PM
what is wrong with turning the ignition off?
Old March 19th, 2012, 06:54 PM
turning the ignition off is a perfectly acceptable response, and could save the engine from blowing too. It's important to remember to just turn it one position so it doesn't lock the steering, or you could be worse off than before.
Of course, this would never happen to someone with a manual transmission, as first response in a panic is to depress the clutch.
Old March 19th, 2012, 06:55 PM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
wouldn’t the steering lock up?
1984 Camel Trophy 110
1995 Range Rover Classic SWB
1992 Range Rover Classic SWB
Old March 19th, 2012, 06:57 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Only if you pull the key out.
Old March 19th, 2012, 07:34 PM
What a shame...and a tragic loss of life. Why can't people be taught to think through a situation. He could have changed gears, used the emergency brake, put the truck in neutral or turned the car off. All of which would have changed the outcome of his accident.
I am sure his family will sue, and Land Rover will pay for his lack of maintenance and ignorance. Why are we such a "It's not my fault" society?
Old March 19th, 2012, 08:13 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
That's a terrible story. I would think that if the seatbelt had been used it would have turned out differently. Granted the front end is completely gone, but the front passenger window isn't even cracked. With airbags deployed the passenger compartment might have been safer than being ejected from it. In a Defender it probably wouldn't matter much
Old March 19th, 2012, 09:41 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
No power steering/brakes and mountain roads between Ogden and Salt Lake.
Neutral and you get power steering and brakes
And if you are a total idiot, you risk locking the steering if you pull the key out...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old March 19th, 2012, 10:08 PM
RedD90's Avatar
RedD90
JNH
'97 D90
Does his Land Rover actually kill him?
Hicktonite
Old March 19th, 2012, 11:33 PM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
The driver was most likely pressing the gas pedal to the floor the entire time, instead of the brake pedal. Don't you guys remeber that whole "unintended acceleration" nonsense back in 1987 that just about killed off Audi in this country?
Old March 19th, 2012, 11:41 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
Doubt it...I have seen the issue with the 97 4.6...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old March 20th, 2012, 12:02 AM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
Gas pedal getting stuck on a Rover? Sure, no problem there. But brakes failing at the exact same time? Sounds exactly like a classic case of driver error. It used to happen a lot before shift lock devices were made mandatory.
Old March 20th, 2012, 04:48 AM
Sad but We may have a story here for the Darwin Award site.
New daily driver...advice anyone? BEIS Misc. Chit-Chat 16 January 31st, 2011 02:26 PM
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 01:03 AM
D90 - Daily Driver - Yes, No or Maybe? uzj100 Misc. Chit-Chat 31 July 26th, 2005 05:43 PM
Plastic parts from driver side window?? Vadim Defender Technical Discussions 1 January 18th, 2005 03:06 AM
Driver side mirror jracenstein Defender Technical Discussions 3 October 22nd, 2004 10:00 PM
» Defender Registry
Anni
Elbee
97DFND
Jn101814
Add your Defender
