Land Rover Garages. - Page 5 - Defender Source
Join the Defender Source Community Today
Old November 24th, 2011, 10:33 PM
Wow, awesome garage, and property/home too!
Originally Posted by pendy
I'm here for the D's
Old November 25th, 2011, 10:17 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Originally Posted by d110pickup View Post
Here's mine; I also did a build thread on Garage Journal.
http://www.garagejournal.com/forum/s...ad.php?t=10218
Mike you have the most amazing setup! You really did some fantastic planning and execution was as close to perfection as I have seen. The ample space to work must make your projects much more organized.
Your garage and home are awesome.
Old November 25th, 2011, 10:16 PM
d110pickup
Mike Pado
'97 D90 ST #1153
Thanks guys, I appreciate the kind words!
I just wanted a neat & useful shop that wouldn't run down the house. And it is a shop and not a play-pretty garage. The garages of the rich & famous are the ones to ooh & ah over not mine.
But I do have fun in the shop.
Old November 26th, 2011, 01:22 PM
oilburner's Avatar
oilburner
JL
large pile of parts
On the epoxy floor thing, I am another who wishes he had sealed the floor instead of put down epoxy. I used really good 2 part epoxy and 1.5 years later it is a disaster of burns and lifted sections. Any type of contamination (stone dust) causes the floor jack to scratch up the floor, and my jack stands have torn up a few sections. As soon as there are openings in the floor, the water gets underneath and starts to lift the epoxy. I probably do more metalwork than most, some of it is pretty heavy, but if you are planning on doing a lot of welding I think epoxy is not the greatest. I have to say though, it was amazing at first, we actually moved a 2800 lbs milling machine with nothing more than dish soap and water. It skated across the floor like a curling rock!
JL
Old November 26th, 2011, 02:58 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
What epoxy did you use? I had none of those issues with the ucoatit system in my old shop. Current floor has sherwin Williams on it and it kinda sucks but the floor is 30 years old. I have worked on floors with the behr floor paint that burned like you mentioned.
Old November 26th, 2011, 03:38 PM
dchapman
Daniel Chapman
1999 D1
Ucoatit will start to lift under hot tires after a few years. Even on fiberglass reinforced floors.
But ucoatit is very easy to clean.
Old November 26th, 2011, 06:43 PM
oilburner's Avatar
oilburner
JL
large pile of parts
It was Sherwin Williams on a new floor (cured 45 days), etched and applied as per their instructions. It held up well for about a year. Burns way too easily, and is very soft.
JL
Old November 27th, 2011, 09:14 PM
Any recommendations on sealants? How is it that the sealer holds up better? Does it get absorbed and the paint not?
Old December 13th, 2011, 01:17 PM
keiphers's Avatar
keiphers
Keith
1997 D90 ST #647
Here's a crappy iPhone pic of my garage with the Range Sport Supercharged and BRG ST... For the record, I've got a GarageTek floor coating.
Old December 13th, 2011, 01:36 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Originally Posted by usadventureracing View Post
Here's mine minus the 110 as it is stored for the winter and will be getting a new gal frame this winter. Two pictures from the first and two from the second floor.
Hey, I know that stairway!
Stay warm...
Keith
Old December 16th, 2011, 10:45 AM
JSBriggs
Nice Keith. Very minimalistic, there is something to be said about simplicity.
-Jeff
Old December 21st, 2011, 10:01 AM
fnagy
frank
1995 d90
not my garage, but someone in Belguim who has an amazing house and clearly loves his D-90
here is a link to there article
http://www.archdaily.com/80795/villa...l-architecten/
Old December 21st, 2011, 10:02 AM
Are my eyes deceiving me, or are there a plethora of disco balls hanging above the cars?
Loves his D90...and Saturday Night Fever!
Old December 21st, 2011, 12:58 PM
dchapman
Daniel Chapman
1999 D1
Darla, I think you're right.
Old December 21st, 2011, 01:19 PM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
Gotta love Belgium...
1984 Camel Trophy 110
1995 Range Rover Classic SWB
1992 Range Rover Classic SWB
Old December 21st, 2011, 03:31 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Not a Land Rover Garage, but it fits the other toy (barely).
I dont have any good pics of what it looked like when I bought the place, but what a mess. I spent $500 if not more at the local dump just cleaning it out. Every STud was sistered up because of termite damage. Also it had only a few cieling joist.
Cleaned it all out down to the studs, added some cieling joints, brought electic to it and installed a little sub panel. Put in some lights (need to add more), and put some flooring for the loft for storage.
It looks bigger than it is, just barely fits my mustang in legnth wise, and If I need to work on it I usually do a 30 point turn to get it like the pics show.
Still on the list -
  • Have a couple spots of sheet rocking left to do, and the cieling under the loft.
  • Add more lighting
  • Get some sort of retractable ladder for the loft
  • Get some interlocking tiles down on the floor (the floor is way to beat up to consider coating or polishing it
  • Strip and repaint the outside of the windows, and the trim
Pictures:
1 - Day I bought the house(Garage in Background)!
2 - a very short time after, This is after I stripped EVERYTHING out ( must have been 10 pick up truck loads full) . down to the studs. This was the one wall without termite damage
3. - Running Electric
4,5 - some random mid work shots
The Rest - As is sits now
Its a bit messy in the pics, but I have 3 projects going on at once right now.
I wish I had room for a larger work bench, the one there is way to small for my liking. Also the damn engine hoist takes up too much room. its actually my neighbors but in return for borrowing it for one small job he told me I had to store it indeffinetly. lol, so basically, he gave me a hoist for as long as I live here.
ID:	45177   Click image for larger version
ID:	45179   Click image for larger version
ID:	45181   Click image for larger version
ID:	45184   Click image for larger version
ID:	45186   Click image for larger version
Old December 22nd, 2011, 05:37 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Here are my future garages. The single is a at grade front load for the wife. The double is a below grade side load. You can't see it from the pic but there is a 6x8 nook to store the tools, work bench, etc in the lower level garage. Will follow up with pics when it's done.
ID:	45223   Click image for larger version
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old December 24th, 2011, 01:18 PM
JBinAlabama
john
Series 2A ..more parts on the way
Park city garage
I talked to a realtor friend here in PC yesterday, he said he showed that 26 car place to someone...."....he said AMAZING! He said the wife even was blown away by the garage part of the 40million property
Old December 28th, 2011, 03:46 PM
oilburner's Avatar
oilburner
JL
large pile of parts
I'm good with that. (visit by Roverguy, forgot to quote)
I was down in Auburn (29 & Sand Hill Rd area) last weekend to pickup a bandsaw from a Toyota guy. He was giving away a Powermatic Model 2. It needs a bit of work but it was FREE!
It also weighs 2750 lbs but that's another story.
Mike that shop is awesome. Post some pics of the bandsaw when you get it home. I'm currently trying to find a way to get a 6500# Hendey 18X42 home. May have to wait until spring due to the snow and ice.
Cheers
JL
Old December 28th, 2011, 04:06 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
I was talking to a LINE X dealer here in Houston that was showing me how they are using LINE X for garage floors now. Lifetime warranty. The catch? 15 bucks a square!
Homes with Unbelievable Garages Willh Misc. Chit-Chat 11 November 14th, 2011 05:32 PM
POE top with Safety Devices Rack ini88 Misc. Chit-Chat 21 February 7th, 2008 04:36 PM
