Lamborghini Doors on My Defender - Defender Source
Old June 9th, 2005, 10:37 AM
gtg067i's Avatar
gtg067i
Christian Shea
1997 Defender 90 Wagon
I saw this earlier this morning on another board I am subscribing to for some car audio advice on my D90. Incidentally I got some info on a rather trick modification I plan on using on the D90, they also had a great deal on some under car neon so you can see the rocks at night! Do you think I should use grade 8 hardware or would that be too much money? I think I can do this mod for like 4 bucks and don't want to break the bank.
ID:	3287   Click image for larger version
I require your largest, cheapest, most alcoholic brewed beverage.
Old June 9th, 2005, 11:11 AM
They do make some that are much more bling, they push out then turn up vertically and they are all automatic, just push a button. But I think they may be a little out of your budget. I say screw doors! just take them off and go doorless!
Old June 9th, 2005, 11:16 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
They even have them for H2's....
http://www.autosportz.com/bodykits_lambo_door_hinge.htm
Old June 9th, 2005, 11:22 AM
gtg067i's Avatar
gtg067i
Christian Shea
I really like how the guy didnt even use the right hardware length, if you look close in the first picture you can see the bolts coming through the A pillar into the cabin. I can't believe someone would be so daft as to do this. I wonder what happens if he ever gets in a wreck?
Old June 9th, 2005, 11:27 AM
It has to be a joke, who in their right mind put a normal door hindge on a car!
Old June 9th, 2005, 11:41 AM
gtg067i's Avatar
gtg067i
Christian Shea
I would think it is a joke, maybe so, but this is not. It came from a car audio shop where a guy was asked to find out why the amp was not working correct. If you look closely you will notice the enclosure has a certain tree trunk quality to it.
ID:	3289   Click image for larger version
Old June 9th, 2005, 11:42 AM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
Golly Josh, and I was going to offer my D to the MTV shop Pimp my ride and see what they could come up with. With ideas and links like these, now all I need are a few strobe lights in place of the spots, a hot tub in the rear tub, take off the winch and put in a washing machine, and turn the stick shift into a vibrator. Malibu here I come...
Old June 9th, 2005, 11:53 AM
Gettolishus!
Old June 9th, 2005, 12:38 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
That feature aides in recovery operations following the major accidents which occur while reenacting Fast & Furious. Rather than body pieces all over, these bolts keep the occupant remains within the cabin.
"Uhh...I think they all leak like that."
Old June 9th, 2005, 02:30 PM
WCURoverD90's Avatar
WCURoverD90
Jason Habbal
1997 Defender 90 #1104
Mike, Talk to Phil (rover4x4) he might be interested
"tell them to phucough"
Land Rover-The Best 4x4xFar
Old June 9th, 2005, 02:52 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
Insert pithy quote here.
door
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
Defender Doors and Door Tops Buckon37s For Sale - Parts 5 June 12th, 2005 06:14 PM
Defender doors for sale Chris Cox For Sale - Parts 6 April 14th, 2005 11:04 PM
defender st doors WhiteD90 Wanted 3 September 25th, 2004 10:04 AM
