L322 - Code P1173? - Defender Source
Old January 30th, 2015, 05:30 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
L322 - Code P1173?
Sorry for the non-Defender question, but I know there are a lot of Land Rover/Range Rover experts here.
anyone know what code P1173 is on an '04 Rangie?
I've been using Allcoms (not OEM) code reader, so I typically don't get the actual LR codes, but my buddy just pulled this code off my rangie while it was at his shop. I had seen an O2 sensor indication when I looked, but wanted to know specifically if Code 1173 was for one of the four sensors in particular or what exactly it was.
Old January 30th, 2015, 05:39 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
Bank 2 (drivers side) downstream sensor. Common fault when the cat goes bad. It likely has a crack in it causing the rear O2 to see a lean mixture.
Old January 30th, 2015, 05:52 PM
Jackie Treehorn
A
1985 (legitimately)
thanks Adam
It's almost time to make a CT tribute wheeling rig out of this Rangie!
extra set of Trellborgs strapped to the roof and rolling in style and comfort at Romp 2016
Old January 31st, 2015, 12:09 AM
transientmechanic
1972 SIII
What year is it anyways? If its a cracked/leaking cat I bet it could be welded up cheap enough. We used to just replace them because they are warrantied by LR to 8 yrs/80k.
L322 Range Rover wheels onto LR3? Talleyrand Misc. Chit-Chat 8 November 29th, 2011 08:36 AM
LR3/ Range Rover L322 rims and tires ron For Sale - Parts 29 November 11th, 2011 07:53 AM
Best Forum for L322 Range Rover?? Raleigh D90 Misc. Chit-Chat 1 February 27th, 2011 03:58 PM
Best website for Range Rover L322/MKIII? SeattleRRC Misc. Chit-Chat 3 January 11th, 2011 10:27 PM
